How rich will it run?
Posted
How rich will my 06 gt run un tuned with a set of 850cc injectors with out a tune? will it damage anything? i just ordered a set and a avo fmic, i need to sell my perrin tmic before i can afford my new turbo. so i was wondering if i went ahead and install the 850's if it would hurt my car that way i could send my stock injectors back for the mail in rebate. i still have a stock turbo. thanks
Posted
From what little I know. IMO your going to need a new base map for the 850's.
You may want to post this in the Tuning forum.
Engine Build - Click Here
Posted
It likely won't even idle on those injectors, and if it does you could wash down your cylinder walls. Get a proper basemap before trying them would be my advice.
Posted
If you can't afford to mod your car, and your car is your daily driver, you shouldn't mod it... or you should wait till you not only have money to finish it, but also fix it when it breaks.
The car should be drivable on 850's un-tuned. It won't be happy, but it will run. But don't go flooring it around and get it tuned ASAP.
(Updated 8/22/17)
2005 Outback FMT
Running on Electrons
