o- c-uTe Posted April 24, 2005 Share Posted April 24, 2005 I filled my tank until it stoped by itself. It was $34.94, so I want to make it even. It clicked on me about 4 times before it finally reached $35.00. When filling it to the max, does it affect the car in anyways? Will the CEL go on? After an hour, I got the CEL and blinking cruise control light go on and stayed on. Check out this Thread to see what kind of problem I have had before. The first time I think I had just filled it up too. I don't really remember. So, has anyone else had this problem or any problem when filling your gas tank to the max? Link to comment Share on other sites More sharing options...
ChE Outback XT Posted April 24, 2005 Share Posted April 24, 2005 As far as I know you shouldn't have any problems filling it all the way to the cap. You have to be careful with diesel because it expands (especially when you have 100 gallons in a tank - the new privates always mess this one up), but gasoline shouldn't be a problem, especially when you drive some of it off right away. Link to comment Share on other sites More sharing options...
o- c-uTe Posted April 24, 2005 Author Share Posted April 24, 2005 I know I didn't put diesel and I went to Chevron. I only go to Chevron or Mobil here in San Diego. Link to comment Share on other sites More sharing options...
Deer Killer Posted April 24, 2005 Share Posted April 24, 2005 yeah, it should drain out... Link to comment Share on other sites More sharing options...
GardenWeasel Posted April 24, 2005 Share Posted April 24, 2005 I filled my tank until it stoped by itself. It was $34.94, so I want to make it even. It clicked on me about 4 times before it finally reached $35.00. When filling it to the max, does it affect the car in anyways? Will the CEL go on? After an hour, I got the CEL and blinking cruise control light go on and stayed on. Check out this Thread to see what kind of problem I have had before. The first time I think I had just filled it up too. I don't really remember. So, has anyone else had this problem or any problem when filling your gas tank to the max? I doubt that six cents worth of gas would do much, but overfilling can screw up the vapor recovery system. To learn more about your vapor recovery system visit: http://www.endwrench.com/current/spring04pdfs/EvapEmission.pdf Link to comment Share on other sites More sharing options...
mwiener2 Posted April 24, 2005 Share Posted April 24, 2005 Make sure you screw the cap on tight....That can throw a CEL My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
KTM 525 Posted April 24, 2005 Share Posted April 24, 2005 Car is not running when refueling right? On my trips down to Florida I routinely fill my minivan a good 3-4 dollars beyond the autostop and never had a problem. 6 cents is laughable and should not cause any issues at all. Link to comment Share on other sites More sharing options...
Ed_T Posted April 24, 2005 Share Posted April 24, 2005 The tank seems to be full on the first clickoff. I tried to go further and got a few cents more. Replaced the cap and got no CEL; am now a 1/2 tank. Link to comment Share on other sites More sharing options...
Avishar Posted April 24, 2005 Share Posted April 24, 2005 Make sure you screw the cap on tight....That can throw a CEL I believe there is a seperate sign for loose or not on cap which is integrated with the fuel sign. When its open there will be an arrow next to the icon of the gas tank Link to comment Share on other sites More sharing options...
f1anatic Posted April 24, 2005 Share Posted April 24, 2005 Apparently the autostop for the pump nearly fills the tank to the mouth. I find myself filling another 25-50 cents worth of gas (to bring it to an even dollar amount: 34.65 to 35) and spilling it all over. Unlike the minivan which can take another 1-2 gallons after the autostop. But they also have 25 gallon tanks... Link to comment Share on other sites More sharing options...
TRS Posted April 24, 2005 Share Posted April 24, 2005 I've found, unlike on my previous vehicles, that the tank is pretty much full by the time the auto shut off is triggered. One of the first times I filled the tank on the Legacy I did my usual top-off (where I could usually get another gallon or two in there) and kept squeezing the handle. I ended up getting gasoline spilling all down the fender, on the tire, on my hand, on my shoes. So now, when it clicks off I only squeeze out maybe an additional tenth of a gallon. Link to comment Share on other sites More sharing options...
charlierh2 Posted April 24, 2005 Share Posted April 24, 2005 get the CEL pulled and see what actually set it off Link to comment Share on other sites More sharing options...
joeyjojoe Posted April 24, 2005 Share Posted April 24, 2005 you guys are crazy. i think every gas station and every car company says "don't overfill". you're screwing with the vapor recovery system. why would you do something like that? just to get to an even dollar amount? okay the dude who added 6 cents shouldn't be too worried. but the dude who added 3-4 dollars ... you're crazy. Link to comment Share on other sites More sharing options...
deneb Posted April 24, 2005 Share Posted April 24, 2005 I don't know how anyone could add 3-4 dollars after the first click. I can't get more that a few cents worth in after the first click. First car I've had that behaves this way, every other car I've owned I could get in another gallon or so after the first click. IIRC, it says in the owner's manual that not fully tightening the cap can cause a CEL, nothing about a CEL if overfilling, or any other warning light other than a CEL. Link to comment Share on other sites More sharing options...
eamiller Posted April 24, 2005 Share Posted April 24, 2005 The problem with overfilling the gas tank is that the Onboard Vapor Recovery system can't work since there is no air gap at the top of the tank. If your ECU decides to run a fuel system pressure test soon after you fill up (if the conditions are right) then you can get a CEL if it doesn't pass. (same with a loose/leaky gas cap). However, the car won't blow up or anything. The point is, don't do it, it's not worth the hassle. Link to comment Share on other sites More sharing options...
RangerMan Posted April 24, 2005 Share Posted April 24, 2005 I didn't read the little sign on the door the first time I filled up. Topped it off with an extra 30 cents (I think that is about .0001 gallons LOL) and ended up with gas on my shoes...no more topping off for me. No CEL either. Link to comment Share on other sites More sharing options...
KTM 525 Posted April 24, 2005 Share Posted April 24, 2005 but the dude who added 3-4 dollars ... you're crazy. I don't know how anyone could add 3-4 dollars after the first click. I can't get more that a few cents worth in after the first click Guys reread my post ,I stated In my minivan I do this............... Link to comment Share on other sites More sharing options...
Sneezy Posted April 24, 2005 Share Posted April 24, 2005 The problem with overfilling the gas tank is that the Onboard Vapor Recovery system can't work since there is no air gap at the top of the tank. If your ECU decides to run a fuel system pressure test soon after you fill up (if the conditions are right) then you can get a CEL if it doesn't pass. (same with a loose/leaky gas cap). However, the car won't blow up or anything. The point is, don't do it, it's not worth the hassle. Words spoken very wisely. Some cars are more sensative than others and climates can play a big part in this. WInter is not as big of a deal as spring/summer/fall are with drastic temp changes. You can round to the nearest nickel or sime safely, the rest can be troublesome to say the least. Link to comment Share on other sites More sharing options...
o- c-uTe Posted April 24, 2005 Author Share Posted April 24, 2005 The problem with overfilling the gas tank is that the Onboard Vapor Recovery system can't work since there is no air gap at the top of the tank. If your ECU decides to run a fuel system pressure test soon after you fill up (if the conditions are right) then you can get a CEL if it doesn't pass. (same with a loose/leaky gas cap). However, the car won't blow up or anything. The point is, don't do it, it's not worth the hassle. I think what eamiller wrote could be my problem. But the blinking cruise control light, whats that all about? Yeah I went six cents over and already spilled a little bit on the fender. Once it auto stops, STOP. About the guy that went 3 to 4 dollars over, he went over in his van not his lgt. Link to comment Share on other sites More sharing options...
deneb Posted April 25, 2005 Share Posted April 25, 2005 My Bad! Apologies... Link to comment Share on other sites More sharing options...
eamiller Posted April 25, 2005 Share Posted April 25, 2005 The Cruise light flashing is apparently something that Subaru programmed into the ECU to keep the system from activating during an active CEL code (i.e. not just stored in history). My guess is that since the throttle is of the "by-wire" nature, the cruise is deactivated for your safety. My guess is that they lawyers had their hand in it (liability and all that). I'll have to ask our powertrain software engineers at work who code engine ECUs all day why they would for sure.. Link to comment Share on other sites More sharing options...
sjg Posted April 25, 2005 Share Posted April 25, 2005 The Legacy is the first car I've known to be truly full when the auto stop on the pump is triggered. I have had the same experiance as the previous posters. There's virtually no room for additional fuel once the auto stop kicks in. Topping off with even a few cents worth of gas (less than it used to be) ends up overflowing the tank. Link to comment Share on other sites More sharing options...
Xenonk Posted April 25, 2005 Share Posted April 25, 2005 Car is not running when refueling right? On my trips down to Florida I routinely fill my minivan a good 3-4 dollars beyond the autostop and never had a problem. 6 cents is laughable and should not cause any issues at all. I dare you to say that back in 1960s.. Keefe Keefe Link to comment Share on other sites More sharing options...
o- c-uTe Posted May 11, 2005 Author Share Posted May 11, 2005 Ok, this time I did not even put gas and I got the CEL and cruise control blinking light. I just pop up again. Does anyone know why I get this cel light and cruise control go on? The dealer don't know why. At this time, both lights are on. This is the third time this as happend to me. Check on page one on this thread to see what I posted before. Someone please help or tell me what to ask the dealer to look at. Link to comment Share on other sites More sharing options...
dbolen Posted May 11, 2005 Share Posted May 11, 2005 Guys, IIRC, the manual says *not* to add more after the nozzle clicks off. I couldn't find it in the online version, but I am certain it is in the real manual. 6 cents certainly shouldn't bother it tho. Cheers, dave Drive softly and carry big torque! Link to comment Share on other sites More sharing options...
