lilrabbit129 Posted July 15, 2010 Posted July 15, 2010 Recently been hearing a "thud thud thud" noise coming from the subie. It sounds as if I'm running over street reflectors, but maybe about half the intensity. It started a week or two ago. At first I would only hear it during accelerated turning ( like onto/off the freeway cloverleaf). Now I'm hearing it even when driving normally. Its most pronounced during highway speeds ( 65-75mph). Any ideas? Thanks so much.
bluesuby Posted July 15, 2010 Posted July 15, 2010 I would check the front lower control arm bushings....do they look cracked with chunks of rubber missing? CV joints might make a banging noise but usually only when you are turning. Check for ripped axle boots. There will be grease everywhere if they are torn.
heferly Posted July 15, 2010 Posted July 15, 2010 bad tires or bad bearing? sometimes you eat the bar, and sometimes...well, he eats you
Max Capacity Posted July 15, 2010 Posted July 15, 2010 bad tires or bad bearing? Yea, I'm thinking belt seperation. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here
korpsepatrol Posted July 15, 2010 Posted July 15, 2010 you could also try loosening then tightening all your lugs on your wheels to torque specs. Could be loose lugs. 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx
HarryN Posted July 15, 2010 Posted July 15, 2010 You might have run over a jogger or hobo and not realized it.
lilrabbit129 Posted July 15, 2010 Author Posted July 15, 2010 Thanks for all the replies. Some of the easier ones ( loose lug nuts ) I can do on my own ( just need to rent a torque wrench somewhere). The harder stuff, such as looking at the lower control arm bushings and wheel berrings, I might have to just take the car into a shop to get looked at. Originally I was thinking that it might have been alignment or one of the tires throwing a wheel weight and being unbalanced?
Max Capacity Posted July 15, 2010 Posted July 15, 2010 If its alignment, you'll see uneven tire wear. I have 129,000 miles and have never needed to have mine aligned. Tire balance, if it's fronts, you'll feel the steering wheel shake between 70-75mph. If it's the rears, you'll feel that in the your seat. There should be a tire iron with your spare tire. Just take it and make sure all the lugs are tight first. Wheel bearings you'll hear a continuous hum while driving. Bushings will just give you sloppy handling. My car was making a light thumping noise the other day to, but as soon as I got on different pavement, the noise stopped. If yours is there all the time I'd look at the tire sidewall, looking for any indentations. May be rotate the tires, see if it changes. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here
korpsepatrol Posted July 16, 2010 Posted July 16, 2010 You can just tighten them down right now to make sure. i am just saying to retorque them later when you have the chance. You will know right away if you tighten them and the noise stops. Do all of them just in case don't just do where you think the noise is coming from. If a wheel weight comes off it can definitely make that noise too so might want to check that. 2008 6mt Legacy Gt Spec B DGM - Not so Stock/Work in progress 2006 5mt Legacy Gt OBP - Sold 2005 5eat Legacy Gt OBP - RIP R.I.P Coxx
lilrabbit129 Posted July 19, 2010 Author Posted July 19, 2010 Thanks for everyone's suggestions. I did try using the tire iron to check if any of the lugs were loose. I couldn't move them without considerable effort. I don't have a torque wrench so I decided to take the car into Discount Tire to get a tire rebalancing. That should take care of loose lugs or a tire balance issue. If that doesn't stop the noise I'll move to the more involved stuff, probably taking it into a shop. I'll keep everyone posted. Thanks again.
lilrabbit129 Posted July 19, 2010 Author Posted July 19, 2010 Got back from Discount Tire. Had them rebalance all 4 tires. They said the front two were ok, but the back two weren't done well at all ( had them done at the dealer). Unfortunately the noise is still there. Next up might be to take it to a shop and have them try to diagnose it.
SATSFYD Posted July 19, 2010 Posted July 19, 2010 So you say it happens only when you "accelerate and turning". Well that means that it has to be something that is getting stress during those two events. (weight shifting) I would first check all the pieces that rotate or have to deal with weight shifting. 1- Start by looking at the tires/tyres. 2- Check you sway bar ends... (end links)they are made of plastic and do tend to break. 3- Look at the front and rear half shafts. Check to see if the CV boots are intact. 4- Check to see if there is something out of place... you just need to get under the car and look at everything. (If you don't know what "things" are supposed to look like get someone who does.) I would rule out tranny and engine. Due to the fact that: the engine would make the noise all the time and the tranny would make the noise when you would drive at any speed. Hope this helps. **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you?
apexjapan Posted July 20, 2010 Posted July 20, 2010 I had something similar a long time ago - turned out to be the front diff. Something that can really only be diagnosed at a dealer, though. Regards, Paul Hansen http://www.avoturboworld.com
lilrabbit129 Posted July 30, 2010 Author Posted July 30, 2010 $900 later and its fixed. Turns out it was a wheel bearing, the right front in fact. The labor took 4+ hours. I also had them do an oil change and the 2 front brakes replaced. Was a bit pricey, but the noise is gone, and my Subie is back to its former glory. It did hurt to have to pay to get my brakes done, specially since with a garage and some basic tools I could have done it myself.
xt2005bonbon Posted July 30, 2010 Posted July 30, 2010 $900 later and its fixed ^Ouch. That's a tad high. I remember paying 400$ to change that exact same thing on a 99 OB. And I thought that was high.
lilrabbit129 Posted August 1, 2010 Author Posted August 1, 2010 It cost about 500 for the bearings. 250 for the front brakes and 40 for the oil change the rest was tax and misc.
joeblow Posted August 1, 2010 Posted August 1, 2010 How many miles do you have on your car? I'm pretty sure the front wheel bearings are warrantied until like 80k miles and rears until 100k because they had some issues. It's cool; I'm with the band
xt2005bonbon Posted August 2, 2010 Posted August 2, 2010 It cost about 500 for the bearings ^Ok. I guess it may be a fair price then. I recall the mechanics charged me 90$ for the actual left wheel bearing and the rest was....labor! But that was a 99 OB. Must be probably a bit more for a newer car.
BruceBruce Posted August 2, 2010 Posted August 2, 2010 nope front wheel bearings are only warrantied to 60k. I know. I came in like 1000 miles after the 60k and they said i was SOL. It cost me 130 and 40mins of me and my friends time to change the bearing. the dealership wanted i think 400 to do it. screw them.
lilrabbit129 Posted August 2, 2010 Author Posted August 2, 2010 Yeah I was at 64k. I would have loved to have done it myself, but such is apartment living. Maybe one day when I get a house with a garage, I can do all these things I keep saying I want to do.
joeblow Posted August 3, 2010 Posted August 3, 2010 Bummer. I busted one of mine sliding into a curb this past winter, but I was only at 40k miles so they took care of it under warranty. It's cool; I'm with the band
