COBB Tuning Posted July 12, 2010 Posted July 12, 2010 http://cobbtuning.com/images_products/L_5341.jpg The COBB Post MAF Hose for the 2008+ WRX, 08+ Subaru STI and 2005-2009 Legacy GT balances form AND function with its smart appearance and turbulence taming characteristics. The COBB Post MAF Hose joins the stock airbox (or optional COBB SF Intake) to the turbo inlet tube by replacing the stock corrugated rubber piece, arguably one of the most aesthetically challenged OEM parts in the engine bay. While the sleek exterior is easy on the eyes, the slick interior is friendly to airflow, feeding a smooth column of air to the turbo. The 4-ply silicone construction has the right compliance to bridge the chassis mounted airbox to the violent motion of a boxer engine being driven in anger, while the steel reinforcement prevents collapse when the turbo is drawing maximum vacuum at wide open throttle. COBB Post MAF Hose: Replaces corrugated OEM tube, smoothing airflow to the turbo4 ply silicone with steel reinforcement constructionCompliance absorbs relative motion between engine and chassisSteel reinforcement prevents collapse under maximum demandChoice of Stealth Black or COBB Blue
Bolksey85 Posted July 13, 2010 Posted July 13, 2010 Wow, a much more useful part over a well fitting FMIC or more sway bars.
COBB Tuning Posted July 19, 2010 Author Posted July 19, 2010 No, this is not an SF intake, it is the hose that connects the intake to the turbo inlet tube.
Black_Rain Posted July 19, 2010 Posted July 19, 2010 How about a group buy! Will this have any affect on any AP maps?
utc_pyro Posted July 19, 2010 Posted July 19, 2010 Do you have a before and after pressure drop test on it vs the oem one? I actually have the gauges, but testing (and results) move product!
