07legacyGTturbo Posted July 12, 2010 Posted July 12, 2010 Hey... I have an 07 lgt. I want to disable the drls. I've searched it but nothing. How do I disable them?
wsucoug Posted July 12, 2010 Posted July 12, 2010 Check the cheap/free mods sticky in the fourth gen legacy forum. I think it's in there
JayRez33 Posted July 12, 2010 Posted July 12, 2010 A quick search for "drl disable" http://legacygt.com/forums/showthread.php/drl-disable-10-minutes-2117.html?highlight=drl+disable
07legacyGTturbo Posted July 12, 2010 Author Posted July 12, 2010 It says it only works for 05-06 models... I need something for an 07...
Speed_Racer Posted July 12, 2010 Posted July 12, 2010 The 07 model year is the same as 04-09 model years. The mod will work for your car. Trust me, I'm from the Internet.
EquinnoxX Posted July 13, 2010 Posted July 13, 2010 It's been awhile since I did mine but I'm pretty sure that tutorial is right. I think I remember it being a blue wire with a black stripe on mine tho. I have an 07
VIIIFe Posted July 13, 2010 Posted July 13, 2010 When you figure it out, post back on here! It isn't clearly stated anywhere, and I don't want to be the guinea pig I have read/searched through everything on it before but never really found a clear answer anywhere for 07...I probably read right over it, though.
LGT Dave Posted July 13, 2010 Posted July 13, 2010 This is the thread you want: http://legacygt.com/forums/showthread.php/new-2007-drl-hid-help-42292p5.html. Basically, you have to cut or remove the Blue Wire with the Black Stripe from the white connector and plug the white connector back in. There are pictures in post #67 of that thread.
landark Posted July 13, 2010 Posted July 13, 2010 This one - blue wire with black stripe. http://img180.imageshack.us/img180/2841/001gui.jpg
