Johnny5 Posted April 21, 2005 Share Posted April 21, 2005 Just wanted people to know that Subaru has released a kit to make access to the pollen filter eaiser. I replaces the back of the glove box to line up with the filter access door. The cost of the kit is $102.00(it includes a filter) and is 1/2 hour labor to get it installed. I'm getting mine installed this weekend. Link to comment Share on other sites More sharing options...
Joe05GTMT Posted April 21, 2005 Share Posted April 21, 2005 Hey this is great news. Hmmm I'd expect this to be under warantee. Can you get the part number for the kit? -- if not the number of your dealer so I can call them and ask. Thanks, Joe Link to comment Share on other sites More sharing options...
Johnny5 Posted April 21, 2005 Author Share Posted April 21, 2005 I also tried to get it covered under warranty, but no dice. Its not considered a defect since it can still be replaced, only its a PITA to do it. I was told this is considered a convenience enhancement. I'll make sure to get the part number this weekend when I get my car serviced. Link to comment Share on other sites More sharing options...
monty1 Posted April 21, 2005 Share Posted April 21, 2005 You may want to check out the following thread for more details on this. The retrofit kit is mentioned a few replies down. http://www.legacygt.com/forums/showthread.php?t=11052 Link to comment Share on other sites More sharing options...
Triple Digits Posted April 23, 2005 Share Posted April 23, 2005 Just wanted people to know that Subaru has released a kit to make access to the pollen filter eaiser. I replaces the back of the glove box to line up with the filter access door. The cost of the kit is $102.00(it includes a filter) and is 1/2 hour labor to get it installed. I'm getting mine installed this weekend. And you can get it for $80 from Dan Perkins Subaru at Subarupartsforyou.com Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted April 23, 2005 Share Posted April 23, 2005 They should give it away to owners. I'll stick with my once a year teardown. Link to comment Share on other sites More sharing options...
longislander1 Posted August 31, 2008 Share Posted August 31, 2008 I was going to start a new post on the cabin filter, but it may be covered here. I just had my wife's '08 Outback in for service after one year and the service manager said I needed a filter for $85. I asked him why it was so much. He said it was difficult to install up under the dash. Is this a normal price? Is replacement needed every year? I'm just curious if this is a necessary maintenance item or just additional dealer profit. Thanks. Link to comment Share on other sites More sharing options...
Copytech Posted September 2, 2008 Share Posted September 2, 2008 I just did mine. It is made out of fiberglass (or plastic). I just washed it in soap and water and let it dry in the sun. Here is a link to the instructions, you will have to register to see them but it is free. http://www.scoobymods.com/forums/showthread.php?t=9719 Link to comment Share on other sites More sharing options...
Copytech Posted September 2, 2008 Share Posted September 2, 2008 Forgot to add it is a little tricky to get to the first time but not at all hard. I was quoted $40 for a new filter and $60 to install. Did it myself for a cost of $0 Link to comment Share on other sites More sharing options...
DrCloud Posted September 3, 2008 Share Posted September 3, 2008 The 07s and 08s have a pocket at the top of the glove box that the manuals folder fits into, and that appears to be removeable. On its bottom (on the top of the main compartment) there seem to be tabs or something. Does anyone know if that pocket comes off with some trick of those tabs? And what's the trick? This would appear to be the solution for later models, if it works. HPH Link to comment Share on other sites More sharing options...
Jon in CT Posted September 3, 2008 Share Posted September 3, 2008 Here are the instructions.MSA5T0706A143323 AC Filter.pdf Link to comment Share on other sites More sharing options...
DrCloud Posted September 3, 2008 Share Posted September 3, 2008 Thank you! It looks similar to the "06+" version on ScoobyMods, but condensed to one page. Harder than I hoped, but do-able. HPH Link to comment Share on other sites More sharing options...
Copytech Posted September 3, 2008 Share Posted September 3, 2008 I wish I had taken some pictures because the scooby mods instructions were close to what my '08 looks like. The second set are a condensed version that doesn't show you how to remove the glove box or the panel to get the filter out. Mine has a pop clip that looks like a screw on the right side if the glove box that holds it in. Under the owners manual cubby there are five more pop clips holding a cover in place. Once the clips are removed the cover needs to be gently pried out. Like I said a little tricky the first time but not hard. on mine the the exact steps are: 1. remove side panel 2. remove strap and glove box hinge pop clip 3. push in on the right side of glove box to release the stop, the glove will come out on an angle 4 remove owners manual cubby 5 remove the five clips holding on the access panel under cubby and gently pry out 6 remove filter and clean, replace, throw the filter away (your choice) install in reverse order Notice that unlike both sets of instructions I did NOT remove any screws. Link to comment Share on other sites More sharing options...
