wrxkilla05 Posted June 27, 2010 Posted June 27, 2010 okay so i dont know alot about brakes but when i brake in my lgt my steering wheel shakes like crazy and that leads me to believe that my brakes are the problem.....but is it pads? rotors? or both? any help would be great thanks
wrxkilla05 Posted June 28, 2010 Author Posted June 28, 2010 thats what i figured but wasnt sure......it only does it sometimes though id say like 65% of the time so does that mean that they are warping? and should i buy all new rotors?
BennnGeee Posted June 28, 2010 Posted June 28, 2010 Take them in and if they are within spec they can machine them if not you will have to purchase new ones.
kneedragger Posted June 28, 2010 Posted June 28, 2010 Take the pads out, rub them on some rough concrete then emery the discs to roughen them up too then go and try ur brakes. Good chance they will be ok.
c-lo Posted June 28, 2010 Posted June 28, 2010 or bent rims? I have steering wheel wobble when I drive at certain speeds and when I brake. turns out all my wheels were bent. 258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos
Max Capacity Posted June 28, 2010 Posted June 28, 2010 Been talked about a 1000 times. Re-bed the brakes. 3-4 all most stops for 50-60mph as hard on the brakes as you can without lock up. drive for at least a mile without stopping. 9 out 10 times problem fixed. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here
