skwosed Posted August 4, 2005 Share Posted August 4, 2005 I've heard this in my realatively new Outback XT and thought it was normal... haven't noticed anything wrong with the suspension or the steering. Should this be mentioned to my dealer? Link to comment Share on other sites More sharing options...
skwosed Posted August 4, 2005 Share Posted August 4, 2005 read the thread... got it now. Thanks Link to comment Share on other sites More sharing options...
waterdish Posted August 4, 2005 Share Posted August 4, 2005 yes see your dealer Dave Link to comment Share on other sites More sharing options...
rporter Posted August 27, 2005 Share Posted August 27, 2005 Reviving an old thread...... I have had the noise as BadAndy described (under 5 mph, either in starting or stopping), and I was about to take it to the dealer, until I drilled down through this topic to find this thread. The info was spot-on!!! The creaking is gone!!!! Took 10 minutes. Well, I already have removed the cover a few moths ago (busted when I punched the lower rad tank, hated the oil filter cover, etc), so it was just a matter of tightening. I used the torque wrench, and all eight of the bigger bolts were loose. Also messed up and hit one of the two front bolts (18 lbs/ft spec) with 44 lbs/ft, and it's stripped but that shouldn't matter. Both of those were a bit loose, also, and need a box wrench on the nut. If it does it again, I'll pull each of those eight bolts and Loctite 'em. Easy enough to do at oil-change time. Thanks, folks!! Ron Link to comment Share on other sites More sharing options...
kanoswrx Posted December 13, 2005 Share Posted December 13, 2005 I want to try this fix right now, to bad I am at work, Might go home for lunch and work on my car. I have had my car make these noises so much when going over pot holes and bumps in the road. I hope this fixes my problem. Link to comment Share on other sites More sharing options...
onesillyracer Posted August 21, 2006 Share Posted August 21, 2006 reviving this thread. i guess this is a common problem, is there any tsb on this? i hear this sound when my car is not moving and i turn the wheel slightly to the left or right. Link to comment Share on other sites More sharing options...
rkl303 Posted August 22, 2006 Share Posted August 22, 2006 I only got this sound when I started gasing or braking. Have you checked the bolts in the H-brace? Mine were fine there but when I took off the belly pan I noticed that the bolts in the front crossmember were very loose(I could unscrew it by my fingers). Anyways I tighted those up and no more noises. I know for audi's that nois is the dreaded sound of either your tie rods going bad or control arms. Link to comment Share on other sites More sharing options...
onesillyracer Posted August 22, 2006 Share Posted August 22, 2006 well to get to the brace, do you need to take off the tire, and the splash guard just to get to the brace? this sounds like a big pain in the butt. Link to comment Share on other sites More sharing options...
rporter Posted August 22, 2006 Share Posted August 22, 2006 No, just the splash guard (or whatever that thing is supposed to be). No big deal, it's no more work than an oil change. In my case, that plastic guard has long-sice hit the trash, so I didn't even have to contend with that. Ron Link to comment Share on other sites More sharing options...
onesillyracer Posted August 22, 2006 Share Posted August 22, 2006 well im horribly mechanically inclined, thus why i asked lol Link to comment Share on other sites More sharing options...
rkl303 Posted August 23, 2006 Share Posted August 23, 2006 No just remove the 3 bolts on the belly pan, and about 4 or 6 popits(thats the worst part) and you can see the front crossmember(there is one popit in each wheel well). I forgot how hard I tighted it but it wasn't excessive. I think I saw once 20ftlbs or something posted by xenonk. I had to do this myself because the bastards at subaru didn't hear it even though I brought it in 3 times. Once I showed them and they just gave me the bull that they checked(I even told them to check the bolts). Link to comment Share on other sites More sharing options...
