SVXdc Posted May 30, 2010 Share Posted May 30, 2010 Some European and Australian Legacy/Liberty models have a different AVN HU (Audio/Video/Navigation) than USDM models. Visionhu posted this picture of the front of a EDM LHD HU and display in this thread: Cornelius posted in the huge 'OEM navi features hack' thread (which discusses the nav found in 2005-2009 USDM Legacies). Since this OEM nav HU is not the same, I thought it would be better to split that discussion off into a separate thread. With any luck, we'll work out the pin assignments for all of the various connectors. [picture of the back of my navi in] EU model 2009 legacy 2.0 Dieselhttp://i39.tinypic.com/j6llqr_th.jpg (click to see larger image) Interesting. Lots of connections there. The (gray) TMC connector suggests this is a Kenwood unit as well. Nothing that looks like camera or video input, thoug - at least not obvious. Is yours DVD based as well or have they moved to storage cards for the maps? my maps are in dvd and there is dual DVD drives for use, navigation disc is constantly in [the second drive], i search that 24pin white connector has aux video input and subwoofer on/output&grounds still not connected. Bought today the pins for the connectors and i'm making it one again. His Navi HU is very similar to the one used in 2008-2011 USDM Impreza and 2009-2011 USDM Forester. I've posted information about tbe USDM version (including pin-outs) in my 'Stock HU info' thread here (2nd half of post #11 in that thread).http://ae64.com/images-e41/Subaru_Kenwood_nav_rear-th.jpgThe white 8-pin socket is for the rear view camera. A European variation of the Impreza/Forester Navi HU adds a socket for a Kenwood RDS-TMC Data Receiver (Radio Data System Traffic Message Channel) (see picture this thread on SubaruForester.org. Also see this thread). Cornelius' Navi has the RDS-TMC socket, plus two additional sockets. The green 6-pin socket looks like one on the 2010 USDM Legacy/Outback nav HUs. In 2010 USDM Legacy/Outbacks, the rear of the Navi HU looks very similar. However, there are significant differences, so that should have its own thread. Here's one:Subaru navigation system -- tips, tricks, lockout override [for 2010-2011 Legacy/Outback] Link to comment Share on other sites More sharing options...
SVXdc Posted May 30, 2010 Author Share Posted May 30, 2010 I have a couple of questions: What other markets and Legacy/Outback model years use a navi HU like the one Cornelius has? Could we see pictures of the front and the label on the top? Link to comment Share on other sites More sharing options...
SVXdc Posted June 14, 2010 Author Share Posted June 14, 2010 atmurray posted several pictures of the harnesses and sockets on the back of his RHD AUDM HU, as well as the label in his thread here on LGT:AUDM Ltd Ed Nav - A/V In, Vid Out & Sub Line OutModel number (for RHD AUDM) is FZDA07MRHF2. Also see these threads on liberty.asn.au:Help with Reverse Camera! How to: Ltd Ed Nav AUX In/Out, Sub Out atmurray found this "Cord Convert" cable from Subaru, P/N H0010AG100 (not available in the US). Price is about USD $50 to $80 (depending on which country you find it). It connects between the HU's 24-pin socket and the car's harness, and adds RCA jacks for aux A/V input, video output, and subwoofer output: http://i47.tinypic.com/2zpmw5c_th.jpgHe drew this wiring diagram, showing which pins it passes through from car to HU and which have the new RCA jacks and other wires:http://i47.tinypic.com/zkq3cp_th.jpgSince this 24-pin socket is so similar to the one on 2008-up Impreza and 2009-up Forester, I strongly suspect that: The subwoofer output is balanced, mono. Pin 24 (labeled as a second "Sub Out Ground") is actually the inverted version of the sub output signal. Pin 12 ("Sub Out") is the positive signal.Pin 14 is likely simply a ground (since the Aux Enable input -- pin 9 -- needs to be connected to chassis ground). We'll need to see the wiring diagrams to find out what pin 1 ("unknown") is. [ADDED:] Pin 1 is used for anti-theft security on these OEM Kenwood satnav HUs in some Subaru models (none in USA). Link to comment Share on other sites More sharing options...
Visionhu Posted June 25, 2010 Share Posted June 25, 2010 Thought to chime in the discussion, may help if anyone needs a hand wiring his car. To be short: installed EDM AVN HU into USDM LGT without any problems. Wiring almost matches the original connectors, had to split some for the INFO part to work properly. Now I only need to source a new instrument cluster, 'cause the trip info is a bit messed up, MPG vs liters/100km, fahrenheit vs celsius etc. All working fine, except the voice guidance, that may be turned off, but just can't find the way to turn it back (either can't find a manual for this HU) Also got the full service manual for this HU, with all diagrams. Link to comment Share on other sites More sharing options...
SVXdc Posted July 21, 2010 Author Share Posted July 21, 2010 Thought to chime in the discussion, may help if anyone needs a hand wiring his car. To be short: installed EDM AVN HU into USDM LGT without any problems. How does the HU connect to the display -- how many cables, and to which socket(s) on the HU? All working fine, except the voice guidance, that may be turned off, but just can't find the way to turn it back (either can't find a manual for this HU) Several Impreza/Forester owners here in the US transplanted the Impreza/Forester Navi into their cars. For most people, everything worked great. A few said that the voice guidance did not work for them. There is a screen where you can adjust the guidance volume, but that did not help. The screen is labeled "NAV. MENU" with volume < > (decrease/increase) buttons at the bottom. There is another button to the right that may be a mute: <))) I think the problem might be that the Vehicle Speed Signal wire was not connected correctly (or that their cars were not providing a compatible VSS signal that the Navi wanted to see). Go to the "Vehicle Signal" screen and check that the "SPD." field reads the correct speed while you're moving. Link to comment Share on other sites More sharing options...
Visionhu Posted July 25, 2010 Share Posted July 25, 2010 I checked my speed signal, its working perfectly. I think it has to do with the navi DVD, as Subaru forgot about Central Europe and I'm forced to use Totyota DVDs Maybe the file system is not exacly the same, and voices work differently than Subaru's (?) Link to comment Share on other sites More sharing options...
SVXdc Posted April 9, 2011 Author Share Posted April 9, 2011 Several people have had problems with some cheap Chinese rear-view cameras with this type of Navi HU (2008-up Impreza, 2009-up Forester, and 2008-2009 European and Australian Legacy/Liberty/Outback). See posts on Forester forums starting here (posts #24 and after). Bottom line: Avoid the cheap-quality cameras. Be sure to test your camera connected to the actual rear camera input before you spend any time installing it (and especially before you disassemble your trim or tailgate, drill holes, cut wires, glue things, etc.). Link to comment Share on other sites More sharing options...
Steu851 Posted October 14, 2011 Share Posted October 14, 2011 as Subaru forgot about Central Europe and I'm forced to use Totyota DVDs Maybe the file system is not exacly the same, and voices work differently than Subaru's (?) Try Volvo RTI MMM2 disks Link to comment Share on other sites More sharing options...
Steu851 Posted October 14, 2011 Share Posted October 14, 2011 Several people have had problems with some cheap Chinese rear-view cameras with this type of Navi HU Is there a list of working camera ? Link to comment Share on other sites More sharing options...
Black Dragon Posted May 2, 2012 Share Posted May 2, 2012 Some European and Australian Legacy/Liberty models have a different AVN HU (Audio/Video/Navigation) than USDM models. Visionhu posted this picture of the front of a EDM LHD HU and display in this thread: [ATTACH]86147[/ATTACH] Cornelius posted in the huge 'OEM navi features hack' thread (which discusses the nav found in 2005-2009 USDM Legacies). Since this OEM nav HU is not the same, I thought it would be better to split that discussion off into a separate thread. With any luck, we'll work out the pin assignments for all of the various connectors. Could you post the part numbers of both the screen and the HU? Link to comment Share on other sites More sharing options...
Black Dragon Posted May 3, 2012 Share Posted May 3, 2012 I think that I've got the part numbers for the LHD HU with Navigation System Stereo deck, 86271AG110 Display assembly-navigation, 86281AG170 Cord assembly-adapter, 86273AG030 Link to comment Share on other sites More sharing options...
xnsy Posted February 10, 2013 Share Posted February 10, 2013 Hi everyone I also got this head unit in Outback 2008MY. Mine is Kenwood FZDA07ELEF2, also known as FZDA07EREF2 FZDA07MRHF2 for other markets. Here is manual for it. I don’t want to replace it with some other system, because something like GX-204 is not much better, and no good aftermarket head units are represented. So I’m trying to make it more useful with available components. The first think which I tried to change is connecting iPhone to that system. I used a Russian analog of GROM-Audio called "Trioma" (it is not 100% same, but looks like it is also using cd-changer inputs), but I couldn’t switch HU to changer mode! Still HU has 20pin connector and iPhone is charging up. Obvious solution is activating AUX, but you would be able to select tracks with steering wheel control. So, who knows if it is possible to connect iPhone (or activate cd-changer)? Another things I ordered is mentioned above cord converter (hope I will activate AUX and install subwoofer), Kenwood TM320 for actual road situation (rather difficult to find), and rear camera (I’ve ordered pins from ae64.com + camera from aliexpress). Hopefully all this stuff will arrive to me in few moths and I’ll make an installation report Link to comment Share on other sites More sharing options...
Black Dragon Posted February 10, 2013 Share Posted February 10, 2013 Hi everyone I also got this head unit in Outback 2008MY. Mine is Kenwood FZDA07ELEF2, also known as FZDA07EREF2 FZDA07MRHF2 for other markets. Here is manual for it. I don’t want to replace it with some other system, because something like GX-204 is not much better, and no good aftermarket head units are represented. So I’m trying to make it more useful with available components. The first think which I tried to change is connecting iPhone to that system. I used a Russian analog of GROM-Audio called "Trioma" (it is not 100% same, but looks like it is also using cd-changer inputs), but I couldn’t switch HU to changer mode! Still HU has 20pin connector and iPhone is charging up. Obvious solution is activating AUX, but you would be able to select tracks with steering wheel control. So, who knows if it is possible to connect iPhone (or activate cd-changer)? Another things I ordered is mentioned above cord converter (hope I will activate AUX and install subwoofer), Kenwood TM320 for actual road situation (rather difficult to find), and rear camera (I’ve ordered pins from ae64.com + camera from aliexpress). Hopefully all this stuff will arrive to me in few moths and I’ll make an installation report Is it possible to help me find a used one along with it's screen for LHD?? Link to comment Share on other sites More sharing options...
xnsy Posted February 10, 2013 Share Posted February 10, 2013 Is it possible to help me find a used one along with it's screen for LHD?? Well, while I was googling that numbers found that - http://www.bildelsbasen.se/?link=item&post_id=24658574 they sell it somewhere in sweden, not sure about details because don't speak swedish But, keep in mind this is really rare HU, and maybe it will be easier for you to install somethink like Kenwood GX-204 Link to comment Share on other sites More sharing options...
Black Dragon Posted February 11, 2013 Share Posted February 11, 2013 I already have GX-204 Link to comment Share on other sites More sharing options...
FroGuidO Posted February 12, 2013 Share Posted February 12, 2013 Hi everyone The first think which I tried to change is connecting iPhone to that system. I used a Russian analog of GROM-Audio called "Trioma" (it is not 100% same, but looks like it is also using cd-changer inputs), but I couldn’t switch HU to changer mode! Still HU has 20pin connector and iPhone is charging up. I’ll make an installation report I'm afraid it won't help you. I tried to install a GROM-Audio on mine and I enabled the AUX entry, but still I can't get it to switch to CDC. You'll get the AUX on the touch screen and the aux button on the HD will switch to the 3.5mm jack entry. No more. But I agree, there must be a way to activate the CDC. If you find it, report. Thanks for the manual, I'll dig in it, just in case. Link to comment Share on other sites More sharing options...
bullit Posted August 17, 2016 Share Posted August 17, 2016 hello everyone. I need KENWOOD FZDA-07ELEF2 / FZDA-07EREF2 service manual or part number of wire harness that connect the radio, cd charger and dvd... i bought a HU, but seller sent me all the cables cutted Could help me anybody? Link to comment Share on other sites More sharing options...
bullit Posted September 7, 2016 Share Posted September 7, 2016 Still i don´t found the part number or the service manual, could help anyone? Link to comment Share on other sites More sharing options...
bullit Posted February 7, 2017 Share Posted February 7, 2017 At last, i got all the wiring diagram to connect the system. is possible install a Navi,CD,BT HU in a car wich doesn´t had before. Works properly Link to comment Share on other sites More sharing options...
K19DLA Posted May 16, 2019 Share Posted May 16, 2019 At last, i got all the wiring diagram to connect the system. is possible install a Navi,CD,BT HU in a car wich doesn´t had before. Works properly I know is an old one but is there any chance that you can share the wiring diagram for the system? Thanks! Link to comment Share on other sites More sharing options...
bullit Posted May 19, 2019 Share Posted May 19, 2019 Sure. The web is http://jdmfsm.info/Auto/Japan/Subaru/ In this web you could find your model, year, and version, after that, you pulse on "wiring diagram" Link to comment Share on other sites More sharing options...
bullit Posted May 19, 2019 Share Posted May 19, 2019 I know is an old one but is there any chance that you can share the wiring diagram for the system? Thanks! http://jdmfsm.info/Auto/Japan/Subaru/ Link to comment Share on other sites More sharing options...
K19DLA Posted May 20, 2019 Share Posted May 20, 2019 Sure. The web is http://jdmfsm.info/Auto/Japan/Subaru/ In this web you could find your model, year, and version, after that, you pulse on "wiring diagram" Great! Thank you! Link to comment Share on other sites More sharing options...
