05Boost Posted May 22, 2010 Share Posted May 22, 2010 Ok im looking for rims for autox only and need some help. I run Street Mod class and 18x8s all seasons are killing me. I want 17x8 or 17x8.5 think x9 would be too wide without rolling fenders. Weight under 18lbs I really want to keep these things light. Tires im looking at running 225/45/17 for now but i want the wide rim for later if i decide to run bigger tires or even just go straight to the wider tires. Suspension: Im running JDM specB rev-A struts with prova springs F4.35kg R6.7kg and rear cobb bar front perrin 25mm unit. So in short: 17x wide enough to fit 245s if I want to later without rolling fenders Under 18lbs Thanks for the help guys! Link to comment Share on other sites More sharing options...
Bolksey85 Posted May 23, 2010 Share Posted May 23, 2010 RPF1's are available in 17x8 and a deep enough offset to clear Brembo's but IDK if it's too aggressive to not need rolling. Link to comment Share on other sites More sharing options...
