Baddog Posted May 22, 2010 Share Posted May 22, 2010 I was going to originally turbo the N/A EJ22 (which still may happen) on low boost. But now I see I can get an EJ20T from http://www.tigerjapanese.com/index.php?page=shop.product_details&flypage=shop.flypage&product_id=30&category_id=11&manufacturer_id=0&option=com_virtuemart&Itemid=26 Has no ECU so I would have to find one. Any other complications I would have to look at? Link to comment Share on other sites More sharing options...
Canyonero Posted May 22, 2010 Share Posted May 22, 2010 wiring harness im guessing. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 22, 2010 Share Posted May 22, 2010 tranny, driveline, rear diff. rueben can get you the ecu easy Link to comment Share on other sites More sharing options...
Baddog Posted May 22, 2010 Author Share Posted May 22, 2010 I was hoping to avoid the tranny and use the stock auto lol. If I need the trans I will just turbo the 2.2. Link to comment Share on other sites More sharing options...
Canyonero Posted May 22, 2010 Share Posted May 22, 2010 what if you have a 5 speed do you still need to source a trans etc.... for the ej20 swap? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 22, 2010 Share Posted May 22, 2010 you dont HAVE to, but if youre going to spend the $$ on a swap for more power, why not include a tranny Link to comment Share on other sites More sharing options...
Canyonero Posted May 22, 2010 Share Posted May 22, 2010 I Just thought that all subie 5 speeds were mostly the same. Link to comment Share on other sites More sharing options...
Baddog Posted May 22, 2010 Author Share Posted May 22, 2010 Regardless of what motor I use the car will get a manual trans down the road (8-10 months) or sooner if it doesn't hold. So I was going to do bigger brakes, rims/tires and motor then the tranny. What are my tranny options for when I start looking for a 5 speed? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 22, 2010 Share Posted May 22, 2010 anything you want, they all work Link to comment Share on other sites More sharing options...
Baddog Posted May 22, 2010 Author Share Posted May 22, 2010 I guess I should say what 5 speed would hold the power that the EJ20T puts out? I haven't a clue what the power they put out even is lol Link to comment Share on other sites More sharing options...
Zues Marine Posted May 22, 2010 Share Posted May 22, 2010 id just get a wrx 5 speed.. theyre (somewhat)easy to break but cheap and easy to fix Link to comment Share on other sites More sharing options...
Baddog Posted May 22, 2010 Author Share Posted May 22, 2010 Yeah hoping to spend about 1100ish on the trans when the time comes. So would I just need the ECU (doesn't the ECU's have the wiring harness on them anyways?) Just pricing things out. Link to comment Share on other sites More sharing options...
Bassnectar Posted May 23, 2010 Share Posted May 23, 2010 Regardless of what motor I use the car will get a manual trans down the road (8-10 months) or sooner if it doesn't hold. So I was going to do bigger brakes, rims/tires and motor then the tranny. What are my tranny options for when I start looking for a 5 speed? put rims and tires off and get the engine work DONE otherwise your pulling it all out again and its gonna cost you more Link to comment Share on other sites More sharing options...
Baddog Posted May 23, 2010 Author Share Posted May 23, 2010 If I put that kind of power on the piece of shit $200 tires I have on there I WILL NOT stop. Engine work? I think I am just swapping. There is no WORK to be redone because it will NOT be rebuilt. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 23, 2010 Share Posted May 23, 2010 damn for 1100 you can get a sti 6 speed Link to comment Share on other sites More sharing options...
Baddog Posted May 23, 2010 Author Share Posted May 23, 2010 How the hell? All I can find on Ebay are WRX trannys for around $800-1600 where the hell are you seeing this? Link to comment Share on other sites More sharing options...
Zues Marine Posted May 23, 2010 Share Posted May 23, 2010 stupid nasioc Link to comment Share on other sites More sharing options...
Baddog Posted May 23, 2010 Author Share Posted May 23, 2010 Guess I need to check there more often. What year of the STI tranny are you seeing on there? Those suckers go for 3k + Link to comment Share on other sites More sharing options...
Zues Marine Posted May 23, 2010 Share Posted May 23, 2010 the hawkeye trannys..06+ some 02-05 also.. granted they arent in oerfect condition but with a few $$ you can fix it up and have a 6speed Link to comment Share on other sites More sharing options...
Baddog Posted May 23, 2010 Author Share Posted May 23, 2010 Well shit. That's great to know. Im gonna need to start a build profile here in a few months Link to comment Share on other sites More sharing options...
ineedmorepsi Posted May 24, 2010 Share Posted May 24, 2010 Just to chime in your 4EAT is the same found in a WRX. Your 4EAT is just as strong as a 5spd WRX trans. Your 4EAT will probably outlast a WRX 5spd glass trans. Your rear diff is the same as a WRX.. R160 minus the vlsd and different gear ratio. The only reason you get a new trans with the engine is to swap to a 5spd manual conversion. Otherwise if your getting another auto they are essentially all the same. They just have different ratios 3.90 4.11 4.44. Personally, keep your stock auto and rear and just put in the motor.. ALSO since your swapping it would be a great idea to drop $550(equivalent to a clutch upgrade) on a torque converter from IPT (just in case you put a 20G turbo later on) bolt it in since the trans is already separated from the engine. Enjoy chirping gears. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 24, 2010 Share Posted May 24, 2010 rear diffs are different, hes got an L Link to comment Share on other sites More sharing options...
Baddog Posted May 24, 2010 Author Share Posted May 24, 2010 What do you mean enjoy chirping gears? lol scaring me here man! Link to comment Share on other sites More sharing options...
ineedmorepsi Posted May 24, 2010 Share Posted May 24, 2010 Let me also point out.. rebuilding or beefing up a subaru manual transmission is $$$$. Over $3000 Swapping a USED 94-05 5spd from non turbo subaru is $1200+ Swapping a USED WRX 5spd is $2000+ Swapping a USED STi 6spd is $3500+ <---I wouldn't even bother with this It's no joke. I thought of it already. My WRX swap with stock GT 4EAT and rear gives me NO issues at 18psi but I'm about to cage my car and get more serious with it, so I'm needing a manual transmission. It does not look good $$ wise. Link to comment Share on other sites More sharing options...
ineedmorepsi Posted May 24, 2010 Share Posted May 24, 2010 What do you mean enjoy chirping gears? lol scaring me here man! Chirping gears mean the IPT TC will shift hard because of reduced slip like power shifting a manual transmission from 1st to 2nd gear at WOT thus causing breaking traction on tires inducing a "chirp".. get it? Link to comment Share on other sites More sharing options...
