SonicSpecB Posted May 22, 2010 Share Posted May 22, 2010 Hey guys i'm running Win7 64bit,anytime i'm logging data it seems to crash goes to blue screen. Error message IRQL_NOT_LESS_OR_EQUAL Thanks for any help in advance. Link to comment Share on other sites More sharing options...
LegacyMUN2k6 Posted May 22, 2010 Share Posted May 22, 2010 Check your drivers for the device, make sure you have the latest ones installed. Could be a problem with the 64bit version of windows conflicting with something. I'd stick with the 32bit version. You could have a overheating problem somewhere along the motherboard. Link to comment Share on other sites More sharing options...
John M Posted May 22, 2010 Share Posted May 22, 2010 If it only happens when you log, I'd say it has to do with the Tactrix driver working with a 64-bit OS. Have you tried running the program in XP compatibility mode? Also run as administrator. Link to comment Share on other sites More sharing options...
SonicSpecB Posted May 22, 2010 Author Share Posted May 22, 2010 Thanks for the advice so far,logging wans't a problem it just recently started crashing the system,plus Learning view works perfectly,and more help would be great.Thanks Link to comment Share on other sites More sharing options...
SonicSpecB Posted May 24, 2010 Author Share Posted May 24, 2010 Anyone? Link to comment Share on other sites More sharing options...
LongHiway Posted May 24, 2010 Share Posted May 24, 2010 I did a quick Google search. It's actually a pretty common problem but, possibly caused by any of your HW devices and maybe a kernal driver. Maybe the SW is issuing a call to a certain memory bank? Just a WA guess. Try a Google search. Link to comment Share on other sites More sharing options...
