rs6er Posted May 21, 2010 Share Posted May 21, 2010 I changed my coolant for 30k service. Burped it a few times. Coolant is at upper level line in the reservoir whenever the car is cool. However, I smell coolant after every drive. I have hosed off the motor and radiator several times, but the smell persists when the engine heats up. Thoughts? Link to comment Share on other sites More sharing options...
tLewis7 Posted May 22, 2010 Share Posted May 22, 2010 Had a similar issue from new on my 2009 lgt. Dealer (Heuberger in Colorado Springs; SUPER FANTASTIC dealer!) found the issue immediately with a coolant system pressure test. There is another coolant reservoir back by the turbo (for the turbo) that has a cap that was leaking a bit. I do not know if the 07 and 09 are the same, but this could be the culprit. Link to comment Share on other sites More sharing options...
rs6er Posted May 22, 2010 Author Share Posted May 22, 2010 I do know where that tank is. I will check the gasket on the cap. Link to comment Share on other sites More sharing options...
j255c Posted May 22, 2010 Share Posted May 22, 2010 Did you burp the system from the turbo reservoir? The air will all escape from there since its the highest point. I have an extra cap laying around too if you need one. Let me know. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
hardball75006 Posted May 24, 2010 Share Posted May 24, 2010 I had this happen with my GTO. I found out later that there were some foam pieces around outside of the radiator (top and bottom) that became soaked with coolant when I drained the radiator. After the coolant change I smelled antifreeze everytime the car would get warmed up. It took about a month for all that coolant in the foam to burn off. It might just be some residual antifreeze somewhere in your engine compartment that needs time to burn off. Link to comment Share on other sites More sharing options...
rs6er Posted May 24, 2010 Author Share Posted May 24, 2010 I think it is finally going away now. Link to comment Share on other sites More sharing options...
devobuzz Posted May 25, 2010 Share Posted May 25, 2010 I had the same prob with oil. Smelled for about 3-4 weeks before it burned off and went away. Link to comment Share on other sites More sharing options...
