SwagUp Posted May 21, 2010 Share Posted May 21, 2010 If anyone has done this what is the procedure you did and how was the outcome ? Thanks Link to comment Share on other sites More sharing options...
ineedmorepsi Posted May 22, 2010 Share Posted May 22, 2010 I've used Duplicolor wheel and caliper paint with no issues. Proper cleaning, sand paper. 1 can of primer, 3 cans of paint, 2 cans of clear and index cars if you are spraying with tires on. Proper way - at least one way If I was to not powder coat and then repaint say BBS, OZ, Volks, etc and wanted high gloss smooth finish with resistance to chipping: -do a quick sand with rough grit -clean wheel with a pre paint solution -spray thick coat with sandable primer -wet sand it with a fine grit -wipe down with damp towel let dry for a sec -spray paint 3 coats of base lightly avoid runs. (have adequate spray distance) -wet sand with fine grit -wipe down -spray 1 last coat of base -then spray 2 coats of clear whatever you desire The Quickie For stockers, rotas, track wheels, just to make it look newer and ok: -clean wheel surface -spray primer -spray 2 base coats -spray 2 clear coats Link to comment Share on other sites More sharing options...
Zues Marine Posted May 22, 2010 Share Posted May 22, 2010 great! Link to comment Share on other sites More sharing options...
gami892 Posted May 22, 2010 Share Posted May 22, 2010 its not the best stuff in the world . i worked for a body shop for a couple of years and if you want the best and durablity out of your paint do this. 1 clean them with prepsol or a wax and grease remover 2 sand them with 100 grit and work your way up to 500 or 600 3 then spary them with this product call bulldog (its tuff stuff make paint still to anything. 4 then spray so self ething primer which gives it another grab. 5 then sand the primer with a 1000 or 1500 grit (wetsand) 6 then clean primer after sand with some wax and grease remover and then use a tack rag to clean any grits of sanding left behind. 7 then respray the bulldog over the primer 8 then spray your color of choice in this part i would recom... u use an acrylic base paint. 9 after paint drys allow to dry 24 hrs or so 10 mount back on car and enjoy Link to comment Share on other sites More sharing options...
T4L Posted June 18, 2010 Share Posted June 18, 2010 I used Rustoleum hammered black paint (more of a gunmetal color). I scraped off as much flaking clear coat as I could. Roughed up all surfaces to be painted with sandpaper (whatever was laying around) Washed with dishsoap then dried 2 coats of primer followed by 2 coats of final color POOF........you just got new wheels for $10 and a little elbow grease. I don't have a close-up before, but here's the car the day I brought it home....the wheels looked rough. http://legacygt.com/forums/picture.php?albumid=544&pictureid=2874 Here's an after of 1 wheel http://i240.photobucket.com/albums/ff76/Chad7907/Mobile%20Uploads/0_1-11.jpg And the whole car http://i240.photobucket.com/albums/ff76/Chad7907/Mobile%20Uploads/0_1-15.jpg Link to comment Share on other sites More sharing options...
Baddog Posted June 18, 2010 Share Posted June 18, 2010 Funny thing I was just about to do this in a couple weeks. This is great info. I really don't know of a good clear coat brand or what not to put on that's in a spray can. Any suggestions for black? (I apologize for jacking the thread slightly) Link to comment Share on other sites More sharing options...
