jj808 Posted May 21, 2010 Share Posted May 21, 2010 I'm looking for suggestions on a good match between aftermarket struts and spring. I'm looking for a good setup for a DD that will only see spirited driving on the street and never on the track. I will be installing the Perrin 22" sway kit along with it and some transmission bushings to firm up the shifts. Link to comment Share on other sites More sharing options...
mustangendsley Posted May 21, 2010 Share Posted May 21, 2010 Koni or Tokico strust with Pink or rallitek springs. Link to comment Share on other sites More sharing options...
jj808 Posted May 22, 2010 Author Share Posted May 22, 2010 Which Koni struts? Link to comment Share on other sites More sharing options...
goneskiian Posted May 22, 2010 Share Posted May 22, 2010 There's only one Koni strut set up that will fit the Legacy. http://legacygt.com/forums/showthread.php/koni-dampers-legacy-35073.html http://www.koni-na.com/cat_search.cfm?mt_id=1&my_year=2007&mak_id=40&mod_id=423&submit.x=30&submit.y=10&submit=Search Cheers! Link to comment Share on other sites More sharing options...
