lil_z_33 Posted May 21, 2010 Share Posted May 21, 2010 can these be added to the stock projectors/headlamps...what if I swapped in projectors with levelling motors from 08+ sti? would that work? Link to comment Share on other sites More sharing options...
winnipegsubaru Posted May 22, 2010 Share Posted May 22, 2010 Bump for a question that I would also like an answer to. Link to comment Share on other sites More sharing options...
slvrlegacygt Posted June 8, 2010 Share Posted June 8, 2010 i dont think it has been done yet you should try it out and let us all know if it works and make a writeup if it does Link to comment Share on other sites More sharing options...
TSiWRX Posted June 8, 2010 Share Posted June 8, 2010 http://legacygt.com/forums/showthread.php/am-first-noticei-139247.html ^ <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
winnipegsubaru Posted June 9, 2010 Share Posted June 9, 2010 My understanding is, if you can get a certain revision of the JDM HID headlights that they do indeed fit into ou USDM cars. Check out http://www.hkc-speed.com/index.php?act=viewProd&productId=214 they sell the corect HID housing for our cars, but they dont have any left in stock (they get them used from somewhere) The only problem is, that the shields inside are for a right hand drive car, so you need to bake them and swap shields from one side to the other. There is a write up on them on this forum somwhere. Also they only have the manual leveling not the auto leveling... Not sure if this helps anyone or not. PS, if anyone knows another place to buy a set of these please let me know as I am in the market. Link to comment Share on other sites More sharing options...
TSiWRX Posted June 9, 2010 Share Posted June 9, 2010 My understanding is, if you can get a certain revision of the JDM HID headlights that they do indeed fit into ou USDM cars. Check out http://www.hkc-speed.com/index.php?act=viewProd&productId=214 they sell the corect HID housing for our cars, but they dont have any left in stock (they get them used from somewhere) Yes (refer to the last post, below), Leke's post details the Rev.D issues. The only problem is, that the shields inside are for a right hand drive car, so you need to bake them and swap shields from one side to the other. There is a write up on them on this forum somwhere. Also they only have the manual leveling not the auto leveling... Not sure if this helps anyone or not. http://legacygt.com/forums/showthread.php/calling-retro-experts-look-inside-jdm-hid-headlamp-93802.html?t=93802&highlight=jdm+cutoff+shield http://legacygt.com/forums/showthread.php/jdm-hid-headlight-shield-options-99874.html?t=99874&highlight=jdm+cutoff+shield http://legacygt.com/forums/showthread.php/usdm-vs-jdm-lightingi-94531.html?t=94531&highlight=jdm+cutoff+shield PS, if anyone knows another place to buy a set of these please let me know as I am in the market. Is JapanParts still active? <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
