fatsuby Posted May 21, 2010 Share Posted May 21, 2010 I need a fmic kit that will fit my 2005 lgt with a STi style turbo/intake manifold....has this been done before or would I have to buy one that fits my lgt and cut/weld it to make it fit..... Link to comment Share on other sites More sharing options...
Balrock Posted May 21, 2010 Share Posted May 21, 2010 http://legacygt.com/forums/showthread.php/gb3-racer-x-itsme-fmic-05-09-lgt-and-08-wrx-134904.html?t=134904&highlight=fmic+gb3 GB is over, but he may have kits left. Link to comment Share on other sites More sharing options...
John M Posted May 21, 2010 Share Posted May 21, 2010 He needs it to fit an STi intake manifold. As far as I know you'll have to hack a standard LGT kit to put the throttle body pipe where you need it. You *may* be able to mix & match with a WRX kit but it's going to be a PITA either way. Link to comment Share on other sites More sharing options...
fatsuby Posted May 21, 2010 Author Share Posted May 21, 2010 http://legacygt.com/forums/showthread.php/gb3-racer-x-itsme-fmic-05-09-lgt-and-08-wrx-134904.html?t=134904&highlight=fmic+gb3 GB is over, but he may have kits left. in this tread the guys sells fmic for 2005+ lgt and 2008+wrx....does this kit fit both a wrx and lgt or are they different kits? if they are the same then a kit for a 2008+ sti should fit a lgt with the same intake manifold/turbo as an STI since 2008+ wrx and sti share the same chassis its just the turbo outlet and the throttle body location that changes.... I'm woundering if a perrin lgt fmic kit with a blow trhough boost tube for sti/wrx would be a direct fit??? Link to comment Share on other sites More sharing options...
finse Posted May 21, 2010 Share Posted May 21, 2010 http://legacygt.com/forums/showthread.php/gb3-racer-x-itsme-fmic-05-09-lgt-and-08-wrx-134904.html?t=134904&highlight=fmic+gb3 GB is over, but he may have kits left. I have this kit with my FP STi style turbo. However, I am not sure how it would work with the sti intake manifold, as the throttle body is in a different location. Link to comment Share on other sites More sharing options...
