subielineman Posted May 18, 2010 Share Posted May 18, 2010 So the battery in my 1999 subaru legacy 2.5 gt died due to the wife leaving the parking lights on. So I charged the battery and went to start it but now it will only sputter and die. The car ran great before, it has 116,000 miles on it and I've never had a problem. I pulled the plugs and they looked ok the only thing I can think of is it's not getting fuel, and yes the tank is full. Just looking for any ideas if any of you have had a similar problem. Thanks, Adam Link to comment Share on other sites More sharing options...
subikid90 Posted May 18, 2010 Share Posted May 18, 2010 Check your fuel pump, it might have gone bad. Also you can check fuses, doubt its the problem though. Sounds ike you are on the track with a fuel issue though. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
kaz98gt Posted May 18, 2010 Share Posted May 18, 2010 I'd pull a plug and make sure you're getting a spark also. I'm not sure how to diagnose a fuel pump issue, but that could also be a good starting point. Link to comment Share on other sites More sharing options...
