Nicholasv Posted May 17, 2010 Share Posted May 17, 2010 Hello New to the Forum And I need help with a stereo and amp install. My buddy just picked up a 96 legacy and we plan to put alot of work into it for a nice daily driver. All the mechanicals check out But the head unit is blown. I already ordered a new Deck and wire harness for that. We have a couple of 10s and an amp to run them. Couple things I need some advice on. 1 Is there a very common or well known Hole in the firewall that is used to run an amp power line? 2 Is there a common place in the trunk where a ground Line is mounted? 3 Removal of the stereo. I have read around about the stereo and what I have gotten so far is the two screws above the radio in the cup holder. and The two under behind/near the ashtray. Is there any other spots I should know about when installing the stereo? Thanks and sorry if this is in the wrong area of the forum. Link to comment Share on other sites More sharing options...
JimmEh Posted May 17, 2010 Share Posted May 17, 2010 i just picked a random rubber plug in the firewall with nothing running through and made a slit in it and pushed the wire through. works great, I did it for 2 amps. Link to comment Share on other sites More sharing options...
subikid90 Posted May 18, 2010 Share Posted May 18, 2010 I have read around about the stereo and what I have gotten so far is the two screws above the radio in the cup holder. and The two under behind/near the ashtray. Is there any other spots I should know about when installing the stereo? Then 4 more to pull the head unit out of the dash. Ebay has cheap head unit adapters for your car. Like said just find a rubber garment and slide the wire in. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Zues Marine Posted May 18, 2010 Share Posted May 18, 2010 under the brakes master cylinder is the hole i use Link to comment Share on other sites More sharing options...
Bassnectar Posted May 18, 2010 Share Posted May 18, 2010 is it easy to navigate the wire through the door panels or where have you guys done it.. the pre out in my car ripped.. so i ran one through my center console but its visiblel in the back seat Link to comment Share on other sites More sharing options...
JimmEh Posted May 18, 2010 Share Posted May 18, 2010 i found it was a pain in the ass to run wire through the rubber tube into the front door. i used a coat hanger and shoved it through and used it to pull the wire. the rear was easy though. for the sub in the back i ran the wire under the kick plates then beside the seat shoved down where you can's see it. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 18, 2010 I Donated Share Posted May 18, 2010 I grounded my amp to the seat belt bolt when I wired up my amp. Just find yourself a random rubber plug to go through. All of the interior panels come out really easy, so running all of your wires hidden shouldn't be a problem -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Nicholasv Posted May 18, 2010 Author Share Posted May 18, 2010 K thanks for all your help guys. ( and the quick replies ) I got the power line through a grommet for the hood release i believe thats what its for. And the Amp is grounded to one of the seat belt bolts. All I need to do now is install the subs and Then the project is done. Link to comment Share on other sites More sharing options...
