rockle3 Posted May 17, 2010 Share Posted May 17, 2010 Hey guys, I was taking off my boost gauge and accidentally pulled out a vacuum line and have no idea where it goes can anyone help? http://i182.photobucket.com/albums/x268/rockle3/IMG_0212.jpg Link to comment Share on other sites More sharing options...
Max Capacity Posted May 17, 2010 Share Posted May 17, 2010 I can't view the picture at work, but I'm guessing it goes forward under the intake manifold to a little round black thing with a small piece of foam on it. There should be a black plastic nipple just hidding under the intake that the line mates to. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rockle3 Posted May 17, 2010 Author Share Posted May 17, 2010 So do I have to take off the manifold? that is gonna suck a lot Link to comment Share on other sites More sharing options...
Max Capacity Posted May 17, 2010 Share Posted May 17, 2010 Oh did I get it right ? No you should be able to slip the hose back on. Use a little dishwashing soap to lube the hose, may be try needle nose pliers and slip it on. Remember I have know idea what your picture shows. I know my line fell off in that area I'm talking about when I pulled the MBC and boost gauge off years ago. It's above the turbo right? The little round black thingy I spoke is forward by the altenator 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rockle3 Posted May 17, 2010 Author Share Posted May 17, 2010 Oh I dont think you got the right hose . The I T-ed the vacuum line for the by pass valve and pulled it out of somewhere near the intake manifold Link to comment Share on other sites More sharing options...
Max Capacity Posted May 17, 2010 Share Posted May 17, 2010 Got it. It goes under the TMIC and connects to a green T at the front center of the TMIC. picture coming soon. Look about 2" down below my fingers. I shook my hose from the BOV and that's where it moves on the other end. http://i185.photobucket.com/albums/x40/92Si/DSCN4209.jpg 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rockle3 Posted May 18, 2010 Author Share Posted May 18, 2010 Really? I found an unused nipple (at least thats what I think it is) on the intake manifold and just routed it there. At least I thought it works. Will look for the green T tomorrow thanks Max Cap Link to comment Share on other sites More sharing options...
Max Capacity Posted May 18, 2010 Share Posted May 18, 2010 Oh...so you can see under there ? I just did some quick shaking of the hose and it looked like that was attached. If the car drives ok and feels good, may be you got it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rexwagon Posted May 18, 2010 Share Posted May 18, 2010 an unused nipple on the side of the intake manifold? Link to comment Share on other sites More sharing options...
rockle3 Posted May 18, 2010 Author Share Posted May 18, 2010 An unused one on the back of the manifold Link to comment Share on other sites More sharing options...
