GEE-OTTO Posted May 17, 2010 Share Posted May 17, 2010 So my 2008 Legacy 2.5i has been having some odd problems (100% stock never launched, and veteran footwork in play all times clutch wise) Over the 2 years of owning my legacy it has driven well ive swapped the diff fluid twice both times for Extra-S (liquid sex) no problem. for the last 5-6K miles i can hear a ringing from the gear box and I get chatter under decel. Not Cool. Called the dealer he said this could be the sign of a bad PP or TOB if so it will be replaced under warranty at no cost BUT i would have to pay for the clutch disc b/c that is a "wear" part not covered under warranty. I just found the disc but it states "Impreza EJ253 99-07 RS/2.5i " nothing for a 08 Legacy 2.5i ????? Link to comment Share on other sites More sharing options...
ece_tim Posted May 18, 2010 Share Posted May 18, 2010 I'd PM FredBeansParts or visit their website. They generally have competitive prices on OEM and aftermarket parts. Link to comment Share on other sites More sharing options...
FredBeans Posted May 18, 2010 Share Posted May 18, 2010 The clutch disc for your car is P/N 30100AA851, $117. This P/N appears to be common with non-turbo Legacies, Imprezas and Foresters going back to the early 2000s. Let me know if there is anything else I can help with. -Rick Link to comment Share on other sites More sharing options...
Max Capacity Posted May 18, 2010 Share Posted May 18, 2010 IMO you may want to upgrade the qualitity of parts in there. I'm not a big fan of the OEM clutch set up. See if the dealer will offset the cost of a better pressure plate. I'm sure Fred Beans can help you out with pricing, they have some nice aftermarket stuff. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
