stepinrazor Posted May 17, 2010 Share Posted May 17, 2010 I just installed a set of 08 Bilstein USDM spec b takeoffs on my 08 Legacy GT. I didnt measure before and after but after installing them it seems like the front is riding a little higher. When I measured from the ground to the bottom sill front to back, the front was sitting 1/2 higher. Is this normal? I'm guessin that's to compensate for the extra weight of the six speed. When I read thru the bilstein posts, it seemed like it was the same height. I thought only the wagons would have the saggy but syndrome but the sedans were fine. Would the 06 spec b springs make this better? Link to comment Share on other sites More sharing options...
Vsick Posted May 17, 2010 Share Posted May 17, 2010 I think the specB tophats sit taller in the front vs the GT. Link to comment Share on other sites More sharing options...
stepinrazor Posted May 17, 2010 Author Share Posted May 17, 2010 Thanks Vsick, but I used the entire stock takeoff so I figured that it should be level front to back. The only thing I can assume is that the USDM spec b takeoffs ride a little higher up front because of the 6 speed tranny. I'm trying to figure out if I used spec b springs from the 06 if it would be any different since I believe the 06 only had the 5 speed tranny and pretty muched weighed the same. Otherwise I guess I'm gonna have to get pinks but I didnt want to have to pay that much more money Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted May 17, 2010 Share Posted May 17, 2010 You could sell the bilsteins to me instead, that would be much cheaper . Out of curiousity why do you choose pinks? They seem so expensive when other options are available. Link to comment Share on other sites More sharing options...
AZP Installs Posted May 18, 2010 Share Posted May 18, 2010 The pinks are a great spring with OEM quality. I ran them on my wagon for a year with my Konis. Nice and stiff, yet still a decent ride. -mike Link to comment Share on other sites More sharing options...
CTATV Posted May 18, 2010 Share Posted May 18, 2010 the spec.b comes on 18s as well FYI. I replaced mine with coilovers last year though... great decisions for only 1000 bucks Link to comment Share on other sites More sharing options...
jagcars26 Posted May 19, 2010 Share Posted May 19, 2010 I've been running pinks since day one on my car. No problems with stock struts or now my HD Bilstiens. Ride is firm but is not uncomfortable by any means. Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted May 19, 2010 Share Posted May 19, 2010 Is this normal? I'm guessin that's to compensate for the extra weight of the six speed. When I read thru the bilstein posts, it seemed like it was the same height. I thought only the wagons would have the saggy but syndrome but the sedans were fine. Would the 06 spec b springs make this better? Its normal. The Spec B tophat is thinker than the regular one. a 3/8 spacer will even it out. i have aftermarket springs and my front is still higher. Link to comment Share on other sites More sharing options...
Chad W Posted May 19, 2010 Share Posted May 19, 2010 Not only is thicker, but it's stiffer too, which means it sags less, so sits higher. Link to comment Share on other sites More sharing options...
stepinrazor Posted May 20, 2010 Author Share Posted May 20, 2010 I've been running pinks since day one on my car. No problems with stock struts or now my HD Bilstiens. Ride is firm but is not uncomfortable by any means. Which pinks did you get? Since you are also running the Bilstiens on an non specb we should have the same weights. Is the drop even front to back. Right now I'm OK with the back but the front is definitely about a 1/2 higher then the back Link to comment Share on other sites More sharing options...
jagcars26 Posted May 20, 2010 Share Posted May 20, 2010 Which pinks did you get? Since you are also running the Bilstiens on an non specb we should have the same weights. Is the drop even front to back. Right now I'm OK with the back but the front is definitely about a 1/2 higher then the back The pinks I'm running are 05 JDM pinks,not sure of the type:confused: My car sit's level although I did buy the rear spacers just in case the front sat high,but I didn't need them as the car sat level with out them. Do a search for "rear butt sag spacers",they may be what you need. Link to comment Share on other sites More sharing options...
