Perrin713 Posted May 17, 2010 Share Posted May 17, 2010 What would I need to buy and install to make 18x8 5x114.3 rota tarmacs fit my 05 LGT? Found a really good deal on some buy know they wont fit my car. Link to comment Share on other sites More sharing options...
JonLGT Posted May 17, 2010 Share Posted May 17, 2010 Adapters. http://cgi.ebay.com/ebaymotors/Wheel-Adapters-5-Lug-5x100-5x114-3-Spacers-1-25-_W0QQcmdZViewItemQQhashZitem563c70b9a5QQitemZ370381207973QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories You should probably get some that are hubcentric, and the proper width for the wheels you have/ are getting. Link to comment Share on other sites More sharing options...
whitetiger Posted May 17, 2010 Share Posted May 17, 2010 ^thats a bad idea. those amout to a 31.75mm spacer. he would need +80mm offset rim to keep in factory form. to the OP, you are better off finding rims in 5x100. Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 17, 2010 Share Posted May 17, 2010 I wonder if the 08+ STi stuff will swap? You COULD make your own hub... Just buy a front and rear, CAD them with the right bolt hole offset, CNC them, heat treat them, press in extended wheel studs, then install them. Or you could just live with 5x100. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
whitetiger Posted May 17, 2010 Share Posted May 17, 2010 only the fronts would work from the 08+sti. we have no solution for the rears. the 00-09 legacy/outback shares a very unique rear setup which is not found anywhere else on any other subaru. the 2010+ guys can do a full 5x114.3 conversion though. there are other threads that discuss some ideas to do the rear conversion for the bl/bp chassis but nothing bolt on from other models will work. Link to comment Share on other sites More sharing options...
executor485 Posted May 17, 2010 Share Posted May 17, 2010 Heard of some ppl getting rims drilled for 5x100, not sure if these would accept drilling though... Is this true, or have I heard wrong? If I pass you on the right, I'm flipping you off. Link to comment Share on other sites More sharing options...
whitetiger Posted May 17, 2010 Share Posted May 17, 2010 ^also a bad idea. unless the rim is designed to have both bolt patterns, you dont want to compromise the integrity of the rim by drilling it. Link to comment Share on other sites More sharing options...
Perrin713 Posted May 18, 2010 Author Share Posted May 18, 2010 Yah, I figured I'm not even going to mess around with the rims. I'll just keep searching for 5x100. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted May 20, 2010 Share Posted May 20, 2010 What do I need inorder to fit 5x114.3? A different car. On the search for a new DD... Link to comment Share on other sites More sharing options...
Drift Motion Posted May 20, 2010 Share Posted May 20, 2010 i wish some manufacture made some 5x114.3 hub for the rear so i can throw my wheels from my s13 onto the LGT Link to comment Share on other sites More sharing options...
brum Posted May 20, 2010 Share Posted May 20, 2010 How bout buy the wheels from your buddy at that great price. Turn around and sell them for a profit (100-200) then buy some Tarmacs in 5x100 Link to comment Share on other sites More sharing options...
