Baddog Posted May 16, 2010 Share Posted May 16, 2010 I am looking on how the change the trans fluid. I am assuming there is a plug on the bottom of the trans? So I just let that drain and refill? Only problem is I heard that it never drains all the fluid. Link to comment Share on other sites More sharing options...
Baddog Posted May 16, 2010 Author Share Posted May 16, 2010 I also wanted to add some trans-x in there to see if it helps the trans at all. Nor can I understand this http://www.rs25.com/forums/f105/t99571-diy-4eat-automatic-transmission-flush.html Very well. Link to comment Share on other sites More sharing options...
subikid90 Posted May 16, 2010 Share Posted May 16, 2010 If you are changing the trans fluid change the filter also. There is a pan on the bottom of your trans much like the oil pan. Take all of those bolts out and drop the pan down. Make sure to support the pan until all of the bolts are out. If I remember correctly we have a plug for the trans to drain the fluid, so drain it first the take the pan off. You will need a new gasket and filter, about $20-30 at napa or carquest. Pull the old filter off and remember how it was in there, then put the new one in. Make sure to get all of the old gasket off of the seal then put the new gasket on the pan, this takes a few tries to find the right direction. Support the pan again and put the bolts back in. I forget what to torque then to, it is in the haynes manual I believe. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Baddog Posted May 16, 2010 Author Share Posted May 16, 2010 I need to not drain 7 quarts I want it ALL out of there. Not just what the drain plug drains. His DIY doesn't work for a 96 because as far as I can tell I don't have a transmission fluid cooler... Link to comment Share on other sites More sharing options...
98LGTLover Posted May 16, 2010 Share Posted May 16, 2010 I have used Trans-X and it makes a little bit of a difference. I think my tranny is beyond the point of no return so it really didn't change it much. Link to comment Share on other sites More sharing options...
subikid90 Posted May 17, 2010 Share Posted May 17, 2010 I need to not drain 7 quarts I want it ALL out of there. Not just what the drain plug drains. His DIY doesn't work for a 96 because as far as I can tell I don't have a transmission fluid cooler... Your radiator cools the trans fluid. Pull the pan then pull the lines on the radiator and it will ALL come out:lol: -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Baddog Posted May 17, 2010 Author Share Posted May 17, 2010 Our inlet/outlet lines for the 96 L are on the right side of the radiator (looking at the front end). I did a flush on it. Seems to shift quite a bit smoother. Only thing is now it feels a little sloppy when putting it into gear. It's smooth and doesn't jerk but when it goes into gear the car feels like it wants to go in a sense. The dipstick shows it just a HAIR (--) past the Full line when hot. Is this okay? Link to comment Share on other sites More sharing options...
98LGTLover Posted May 17, 2010 Share Posted May 17, 2010 Tranny fluid being just a little too low or a little too high actually makes a difference. You might want to take a little out. Link to comment Share on other sites More sharing options...
Baddog Posted May 17, 2010 Author Share Posted May 17, 2010 Whats the best way to take some out? Also I am a little worried after I first drove it for about 15 minutes (no redline) came back popped the hood to check the levels and it was sorta steaming a bit but stopped. Link to comment Share on other sites More sharing options...
98LGTLover Posted May 17, 2010 Share Posted May 17, 2010 Well.. The best way is if you have a shop you can go to where they have a thing to put down in the dip stick hole and just suck a little bit out. Because if you go back under the car and try it you will lose more than you want to. I really don't know anything about the second half of your comment though, sorry! Link to comment Share on other sites More sharing options...
Baddog Posted May 17, 2010 Author Share Posted May 17, 2010 I will just use the flushing technique I did to get a little out (put it in a clean container in case I need to re-add some. And then fill it up slowly if its a little too low till I get it right on the money. Link to comment Share on other sites More sharing options...
B-BGTLimited Posted May 17, 2010 Share Posted May 17, 2010 Your radiator cools the trans fluid. Pull the pan then pull the lines on the radiator and it will ALL come out:lol: no it wont... You will still have about 4-5 quarts in your torque converter and various valves and pistons through your transmission. The only way to get a dry trans is to take it out and take it all apart. Trust me I just did it on my Beretta because I burnt a clutch pack... I had to take every little thing apart and clean it all to get all the metal and clutch material out of there. The best you can do is bring it to a shop for a trans fluid flush, that will get the majority of the bad fluid out. Link to comment Share on other sites More sharing options...
subikid90 Posted May 17, 2010 Share Posted May 17, 2010 no it wont... You will still have about 4-5 quarts in your torque converter and various valves and pistons through your transmission. The only way to get a dry trans is to take it out and take it all apart. Trust me I just did it on my Beretta because I burnt a clutch pack... I had to take every little thing apart and clean it all to get all the metal and clutch material out of there. The best you can do is bring it to a shop for a trans fluid flush, that will get the majority of the bad fluid out. Okay you got me haha, but without taking anything out it is the most you can get out. He added trans-x so he will be changing the fluid again so he should be most of the bad fluid out by then. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
kaz98gt Posted May 18, 2010 Share Posted May 18, 2010 I need to change out the transmission fluid on mine, it's been over 1k since I did the trans-x, and hopefully I can get most of the fluid out. Link to comment Share on other sites More sharing options...
subikid90 Posted May 18, 2010 Share Posted May 18, 2010 I need to change out the transmission fluid on mine, it's been over 1k since I did the trans-x, and hopefully I can get most of the fluid out. If you can drain everything out of the pan and the radiator/lines and then fill it up. Do this 2-3 times and on the last time change out the filter and you should be good to go. Or if you want to spend a lot of money have a tranny flush done somewhere. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
kaz98gt Posted May 18, 2010 Share Posted May 18, 2010 I've gotta do this one cheap unfortunately. I saw the DIY over on sl-i and thought that would be a good idea for a first time job to get everything all set. What do you guys think? Link to comment Share on other sites More sharing options...
B-BGTLimited Posted May 18, 2010 Share Posted May 18, 2010 If you can drain everything out of the pan and the radiator/lines and then fill it up. Do this 2-3 times and on the last time change out the filter and you should be good to go. Or if you want to spend a lot of money have a tranny flush done somewhere. Depends on what type of fluid you use... LOL I use Dextron VI in my GM and I'll tell you what, It costs $92 to fill a dry transmission (12 quarts). I did that twice this year so far since the first time I built it I got a C-clip inverted and cooked a clutch pack... All the fluid was toast and the whole thing had to come apart to be cleaned before re-assy. Somewhat of an expensive f-up... Either way the best way to get most of the fluid out is via a trans flush... Or you can try to disconnect the pressure line to the radiator and put that into a large drain bucket and while watching that have someone else pouring in fluid while the car is running... Its somewhat a 3 person job, one at the key to shut it off when you run out of fluid to pour in, one pouring and one catching. I've heard of this method, but its not the best, since you kinda cant pour as quick as its pumping out. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted May 18, 2010 I Donated Share Posted May 18, 2010 I am looking on how the change the trans fluid. I am assuming there is a plug on the bottom of the trans? So I just let that drain and refill? Only problem is I heard that it never drains all the fluid. There are two types of transmission services. 1- flush hook into the transmission cooler lines with a machine to get 100% of the fluid. Any shop will have a machine for it. The only downfall to this is that if your car has a lot of miles on it (over 100,000) a flush can wash the varnish off of the gears and cause the transmission to slip. 2 - drain and fill a drain and fill is just draining the pan out. this only gets about 1/3 of the fluid but is the safer method if your car has a lot of miles. When I do this type of service, I usually go ahead and replace the pan gasket and filter as well. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
