blongo804 Posted May 16, 2010 Share Posted May 16, 2010 There's a problem. Either the whole engine is blown or major parts need replacement. I'm thinking of buying an STI engine to replace it since I can't find an actual SpecB engine. How would this affect the car? Would the Si drive components still work? This is my first post, by the way. Glad to be a member here! Thanks for any help in advance! Link to comment Share on other sites More sharing options...
Irimis Posted May 18, 2010 Share Posted May 18, 2010 Well there almost no difference between a Spec B and an LGT, OBXT, and well any of the 2.5 turbos engines. I doubt you will have any problem finding a 2.5 turbo engine. Link to comment Share on other sites More sharing options...
natedog Posted May 19, 2010 Share Posted May 19, 2010 ecu swap for sti motor however the lgt obxt 2.5 motor is the same minus ic turbo intale and exhaust Link to comment Share on other sites More sharing options...
