croll326 Posted May 14, 2010 Share Posted May 14, 2010 Blasted the red from the grille, paint with cold galvanizing paint and two coats of satin black. Switch out the hardware for stainless steel socket hear cap screws and lock nuts. What do you think? I will try to make an install walk through.....stress TRY Link to comment Share on other sites More sharing options...
proflatlander15 Posted May 14, 2010 Share Posted May 14, 2010 Nice! Stealthy, but the SS screws give it some flair. Link to comment Share on other sites More sharing options...
Code Posted May 14, 2010 Share Posted May 14, 2010 Nice. I stealthed mine last year but the winter has corroded the hardware. The stainless is a nice touch. "Striving to better, oft we mar what's well." - Bill Shakespeare - car modder Link to comment Share on other sites More sharing options...
croll326 Posted May 14, 2010 Author Share Posted May 14, 2010 Now I just have to install them....hope its not too complicated. I made a bracket to mount them from aluminum bar and painted sating black to match. Hope all goes well! Link to comment Share on other sites More sharing options...
Windy Road Posted May 14, 2010 Share Posted May 14, 2010 Looks just like mine, black with Stainless hex hardware. I need to pull my off again and repaint them from the winter. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
GearOnePerformance Posted May 15, 2010 Share Posted May 15, 2010 painted hellas are nice! i painted my buddys gold to match his bbs's on his sti Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 15, 2010 Share Posted May 15, 2010 I thought about painting mine, but you can BARELY tell anything is amiss unless you are looking for them. I think the bracket was key. I used a piece of 1/8" steel painted wrinkle black (all I had in my toolbox). I also mounted my bracket straight cross, bolting it to the AC condenser mounts, as well as the vertical radiator support. That way, no matter what, the horns can't flex into the condenser and put a hole in it like all the WRX guys are having problems with. I really should have taken install pics, because it's a pretty great mounting method. I probably will take pics next time my bumper is off, and I install 4 more horns with revised wiring. http://i267.photobucket.com/albums/ii287/bac52/Mobile%20Uploads/3372e4b0.jpg http://i267.photobucket.com/albums/ii287/bac52/Mobile%20Uploads/fb18156c.jpg http://i267.photobucket.com/albums/ii287/bac52/Mobile%20Uploads/cc123fc9.jpg [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
croll326 Posted May 16, 2010 Author Share Posted May 16, 2010 finished product... I used a 1" wide x 10" long by 1/8" thick aluminum bar to mount the horns. I painted it with satin black engine paint and used the hood latch for a mounting point. Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 16, 2010 Share Posted May 16, 2010 I'd be careful with that mount. Loads of WRX guys are having to replace their A/C condensers after their supertones flex into them at speed and put holes in them. I used the same hole you did, but had my bar (which was steel, not aluminum) span over to the condenser mount. Where the condenser mounts to the support brackets, I used longer bolts, through my bracket, and through the factory support and into the core. If the horn mount flexes, it simply moves the condenser. No chance of rubbing. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
croll326 Posted May 17, 2010 Author Share Posted May 17, 2010 O jeez....thats not good. Maybe Ill double up the thickness to a 1/4" thick. That would be ok i think. Can you take a pic of what you did? Link to comment Share on other sites More sharing options...
BAC5.2 Posted May 17, 2010 Share Posted May 17, 2010 I can see if I can get a pic tomorrow morning. Kind of a pita to remove the bumper just for a picture. When I go to 8 horns, I'll probably change the bracket slightly. [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
croll326 Posted May 17, 2010 Author Share Posted May 17, 2010 o ya. If you cant get a pic with just the grille removed dont worry about it. Link to comment Share on other sites More sharing options...
croll326 Posted May 17, 2010 Author Share Posted May 17, 2010 Maybe I can get a small piece of angle and notch the ends for the horns....it would be much stiffer. Link to comment Share on other sites More sharing options...
mccorry Posted May 17, 2010 Share Posted May 17, 2010 Did the same thing to mine some time ago... still looking great. Link to comment Share on other sites More sharing options...
croll326 Posted May 17, 2010 Author Share Posted May 17, 2010 Did the same thing to mine some time ago... still looking great. Use an angle with notched ends or painted them? Link to comment Share on other sites More sharing options...
jmorris6689 Posted May 17, 2010 Share Posted May 17, 2010 I painted mine white to match my car Link to comment Share on other sites More sharing options...
croll326 Posted May 18, 2010 Author Share Posted May 18, 2010 I am going to use a piece of bent aluminum plate. It will be much stiffer. I will post pics when I get it. Link to comment Share on other sites More sharing options...
E-Tank Posted May 18, 2010 Share Posted May 18, 2010 I've been thinking of getting Hellas. I'd paint the grilles blue to match the ABP. I always like the way they look behind an aftermarket grille. I think it may make my front end a little too "busy" though. Link to comment Share on other sites More sharing options...
mccorry Posted May 21, 2010 Share Posted May 21, 2010 Use an angle with notched ends or painted them? Both, actually. Link to comment Share on other sites More sharing options...
croll326 Posted June 1, 2010 Author Share Posted June 1, 2010 New mounting bracket....1" x 1/2" x 1/8" thick aluminum angle. MUCH stiffer than a piece of flat bar. Link to comment Share on other sites More sharing options...
