Difficulty in installing Stock Airbox, please help!
valerka
I was replacing my SPT intake with a stock air box from an 05 LGT, and after removing the SPT I still have a sort of a rubber monting thing with a bolt on top which used to have the mounting bracket for SPT intake connected to.
Te problem is that I am not able to remove that part, and it looks like one of the the mounting bolts for the air box is supposed to go in that spot. Does any one know what I am talking about, it is the two bolts that connect to the frame at the bottom.
Is there any difference in air box setups from 2005 and 2007? Is there a special way to remove that mounting bolt?
Thank you all!
