dante2699yahoo.com Posted May 9, 2010 Share Posted May 9, 2010 I had the MAF disconnected and it still ran. When before it would shut off. Now it keeps runnin. Why is this? Or is it suppose to keep running? Link to comment Share on other sites More sharing options...
kaz98gt Posted May 9, 2010 Share Posted May 9, 2010 you literally had the wire unplugged? I'm gonna try this and see what happens, but I remember another time I tried it and the car ran like shit then quit. did yours run fine? Link to comment Share on other sites More sharing options...
amp27 Posted May 9, 2010 Share Posted May 9, 2010 my guess is the car was in a failsafe and was not using the maf for fuel air mixing Link to comment Share on other sites More sharing options...
subikid90 Posted May 9, 2010 Share Posted May 9, 2010 my guess is the car was in a failsafe and was not using the maf for fuel air mixing +1 -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
Bassnectar Posted May 10, 2010 Share Posted May 10, 2010 yup car was in limp mode. did your cel come on? Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted May 10, 2010 Author Share Posted May 10, 2010 Well CEL has been on. So yes its on. LOL. But, the one time I pulled it off. It choked out. Well I drove it to my parkin spot and it backfired once. But it had power. I'm thinkin I need an O2 sensor. And a ignition coil. Car runnin like shit. Its gettin to me. I didn;t want to put in the shop.; But I did. And they didn;t tell me anythin I didn;t know. And it really piss me off. So if anyone know wherre I can get a ignition coil that would help a lot. Therre is none around herre. How shockin? lol. Right. Link to comment Share on other sites More sharing options...
Chuckadian Posted May 10, 2010 Share Posted May 10, 2010 Mine runs fine with the MAF unplugged too. Does this mean I am in limp mode? How do I reset it? Edit: I don't have a check engine light on Link to comment Share on other sites More sharing options...
amp27 Posted May 10, 2010 Share Posted May 10, 2010 weird. maybe its for sho. haha. and you shouldn't just buy random stuff. waste. have your car read or buy a scanner. Link to comment Share on other sites More sharing options...
Bassnectar Posted May 11, 2010 Share Posted May 11, 2010 ya like amp said, if you get on local car forums you can find others who have the scanner who will most likely do it, if not autosource, part source places will scan for free and let you know what you should try replacing. it will tell you if you need the oxygen sensor, and might say something about misfiring or so if its an ignition coil. DONT waste your money until you know though. I have an aftermarket maf, but i dont want to unplug it i dont see why your running it without it. the earlier time when it did stall out, perhaps your car wasnt in full limp mode and was still using it to adjust air/fuel ratios, Was your car running better in general around the time it stalled out? because now that it is not working your car should be running like shit on preprogrammed timing and ratios. Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted May 11, 2010 Author Share Posted May 11, 2010 Oh its runnin like shit. Link to comment Share on other sites More sharing options...
Bassnectar Posted May 12, 2010 Share Posted May 12, 2010 was it running better when your CAR STALLED WHEN U UNPLUGGED THE MAF?? or was it running like shit the whole time, im thinking your car is in full on limp mode, Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted May 12, 2010 Author Share Posted May 12, 2010 I was just thinking that after you mention it. I didn't know a manual could do that. DUH! So what could be causing it? MAF, Ignition coil, Catalytic Converter, O2 sensor? Link to comment Share on other sites More sharing options...
familydad Posted June 11, 2010 Share Posted June 11, 2010 just an fyi, there was a mass recall in 08 on the mafs, Apparently, they had a problem with the silicon sealing gel used around the sensor base. The silicon can seep onto the sensing element causing it to malfunction. contact your local Subaru dealership to see if the airflow meter on your car has already been replaced or would be covered by this recall (#WWG-90). Link to comment Share on other sites More sharing options...
987687 Posted June 16, 2010 Share Posted June 16, 2010 Why are you replacing ignition parts? Coil and whatnot? If it runs better without the MAF (and it runs pretty awful without the MAF...) it means you need a new MAF. They're like $20 at most junk yards and rarely fail. Pick one up and be done. Link to comment Share on other sites More sharing options...
