grizzlepuss Posted May 8, 2010 Share Posted May 8, 2010 ECU is throwing a purge solenoid code and I am in no way interested in replacing it because I'm assuming it's stuck open..... Anyway, is there a way to clear the code so the check engine light isn't always on?? Thank you Link to comment Share on other sites More sharing options...
Zues Marine Posted May 8, 2010 Share Posted May 8, 2010 disconnect the battery, let it sit for .5- 1hour, reconnect... this resets your ecu or scanguage 2 clears codes, and most obdII from autozone or simialr stores do it free Link to comment Share on other sites More sharing options...
grizzlepuss Posted May 8, 2010 Author Share Posted May 8, 2010 disconnect didn't work..... is there a certain configuration that needs to be set up? I have the "green plugs" connected to read the code. When I disconnect the green plug, I get a solid CEL. When they're connected I get three long flashes follwed by five short ones. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 8, 2010 Share Posted May 8, 2010 then you didn't leave it disconnected long enough i leave mine disconnected for a few hours Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted May 8, 2010 Share Posted May 8, 2010 take it to a parts store Link to comment Share on other sites More sharing options...
amp27 Posted May 9, 2010 Share Posted May 9, 2010 i do that and the lights just come back on after the next cycle or what not. i cant judge about what broken though cause i dont know what it is. ha Link to comment Share on other sites More sharing options...
Zues Marine Posted May 9, 2010 Share Posted May 9, 2010 its always going to come back on if you never fix the problem.. i suppose you can take out the bulb Link to comment Share on other sites More sharing options...
kaz98gt Posted May 9, 2010 Share Posted May 9, 2010 there's a green-clipped wire underneath that did it for mine, but I doubt that's a cure-all. mine was unplugged when i got the car, but when I hooked it in I got a misfire code and it was flashing all the time (the monkeys probably didn't hook it up when they did the engine swap), so I just left it unplugged. I did get a CEL the other day about the egr, so it's probably just one or two sensors in that wire that's unplugged. Link to comment Share on other sites More sharing options...
amp27 Posted May 9, 2010 Share Posted May 9, 2010 i have wires unplugged too. its probably normal cause the harnesses are designed to work in different models to. Link to comment Share on other sites More sharing options...
ehsnils Posted May 9, 2010 Share Posted May 9, 2010 Just try to figure out what's wrong with the purge valve first and if you can't make it work get a new one. The CEL will come back until the problem is fixed, and you may want to have it there for other problems. Link to comment Share on other sites More sharing options...
grizzlepuss Posted May 9, 2010 Author Share Posted May 9, 2010 Is there any walkthrough or info on swapping out a purge solenoid canister? Link to comment Share on other sites More sharing options...
ehsnils Posted May 9, 2010 Share Posted May 9, 2010 Try to get the Haynes manual for your car - or look at some "Vacation Pix". Link to comment Share on other sites More sharing options...
Bassnectar Posted May 9, 2010 Share Posted May 9, 2010 idk if thats putting your car in limp mode but sometimes driving with the cel is bad because it puts your car into pre programmed timing and your mileage will be the first thing to get screwed Link to comment Share on other sites More sharing options...
JimmEh Posted May 9, 2010 Share Posted May 9, 2010 then you didn't leave it disconnected long enough i leave mine disconnected for a few hours disconnect the battery (both terminals) and put your foot on the brake for 30 seconds. it will drain any residual power. this worked for me a few days ago when checking mine. Link to comment Share on other sites More sharing options...
Bassnectar Posted May 10, 2010 Share Posted May 10, 2010 when i had a cel it should only take 30 seconds if u disconnect the battery, but if the system redetects it its gonna pop back up a 60$ odb2 scanner can clear it up for you anytime you want, even while the vehicle is driving Link to comment Share on other sites More sharing options...
kaz98gt Posted May 10, 2010 Share Posted May 10, 2010 ^^ obd2 scanner is the best. get that plus PROscan and you're all set. you can pull up codes, get accurate information from all the sensors on the car, run diagnostics, have an on-board "dyno" (haven't had too much luck with it)...it's all there. and it'll clear codes for you; it's definitely worth the investment. Link to comment Share on other sites More sharing options...
Zues Marine Posted May 10, 2010 Share Posted May 10, 2010 scangaugeII Link to comment Share on other sites More sharing options...
amp27 Posted May 10, 2010 Share Posted May 10, 2010 localshopII. great scanner. even gives you verbal feedback and can order your parts automatically. its a great scanner for the beginner!! Link to comment Share on other sites More sharing options...
Zues Marine Posted May 10, 2010 Share Posted May 10, 2010 mostpeopleatlocalshopsdontknowanythingaboutcarsII Link to comment Share on other sites More sharing options...
something different Posted May 11, 2010 Share Posted May 11, 2010 green plugs are normally not pluged togeather. they are for a test mode. fix it or it will just come back on. Link to comment Share on other sites More sharing options...
