05legacygtturbo Posted May 11, 2010 Author Share Posted May 11, 2010 I also want to add that a compression test was done and is fine. The pasenger side was low compression,but nothing to indcate an internal failure. Like pistons,heads,cam. I guess I got lucky and it only needs cleaned out and new seals, and gaskets. Also of course the turbo. Link to comment Share on other sites More sharing options...
mwiener2 Posted May 11, 2010 Share Posted May 11, 2010 one head much lower compression than other points to a head gasket issue... usually. You should run far far away My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
HDTurbo Posted May 11, 2010 Share Posted May 11, 2010 I would get in writing *all* the parts and labor that is "agreed to" for that price and compare that with your educated expectations. You added piston/rings in a previous post. As an experienced consumer, don't cheerfully assume anything. Not trying to rain on your parade; but suggest you trust but verify...there's no free lunch. Link to comment Share on other sites More sharing options...
05legacygtturbo Posted May 11, 2010 Author Share Posted May 11, 2010 I have all in writting, and actually going to pay for it all tom. Engine re build and turbo is on the agreed terms. That covers all gaskets,seals,timing belt,new turbo etc. Link to comment Share on other sites More sharing options...
Max Capacity Posted May 11, 2010 Share Posted May 11, 2010 IMO your not getting a engine rebuild. Your getting an engine inspection. A rebuild includes new rings, bearings and machine work. As long as he's sure he can get all the metal out, if the compressor blade really came apart...how bad was the turbo ? May be most of us are thinking the turbo really came apart ? If it's not that bad, that's good for you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mwiener2 Posted May 11, 2010 Share Posted May 11, 2010 Changing a timing belt and idlers and such on the front of the engine is not a complete rebuild. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
05legacygtturbo Posted May 12, 2010 Author Share Posted May 12, 2010 Sorry if I have confused some of you. I may also be wording things wrong also. I paid today for a new turbo and all the stuff for it. New lines,screens etc. I also paid for the timing belt and tensionors, pullies. The agreement was also and I have in writing was to completely tear down motor and replace the enigine seals and so on. There is no internal damage. The engine re seal is a precaution for any gaskets and seals that could have been affected by the metal in the oil pan. Total bill with all parts and labor and tax was 3250. Link to comment Share on other sites More sharing options...
AshyLarry Posted May 12, 2010 Share Posted May 12, 2010 Cant say we didnt warn yah. But I hope it all does work out in your favor. Just not too common to see someone get a good deal these days. Link to comment Share on other sites More sharing options...
Vitamin_G Posted May 12, 2010 Share Posted May 12, 2010 If the shop didn't have a lot of overhead, I don't see why this deal couldn't be reasonable. I'm sure he's also paying a lot less for parts than what you would see on the receipt or what Subaru would quote you. If business is slow, then even more reason to cut a deal on labor. Link to comment Share on other sites More sharing options...
