5EAT TCU Reverse Engineering
utc_pyro
  • Replies 614
  • Created
  • Last Reply
Top Posters In This Topic
roadie, i think i had a little ah ha moment. For the ID, it might be 410 because the hex values match to the link i shared
Yeah. I saw that the second byte at 410 was increasing while I accelerated.
Hooked up a spare TCU to see what would happen on the canbus.
http://i.imgur.com/EwEI9vC.jpg?1
Didnt expect this, maybe something was wrong. Had to select "listen only" in settings instead of "active" as last time in the car. Will have to try "listen only" in the car to verify. Period=0 ?
http://i.imgur.com/AYTlNmV.png
Edited by roadie08
Sick. Now im assuming we can edit anything we want on it now?
Not untill you fire up IDA or a hex editor and see if you can find anything. There are also online disassembaly programs that support this CPU if you don't want to deal with the cost or hassle of setting up IDA.
which cpu is it so I know what im looking for. Im going toi see if I can find some hex editor that supports our cpu. so far I am able to open the files but from there i dont know since I know nothing when it comes to programing
'05 USDM ROM is up thanks to the OP donors that bought the thing, ClimberD, and Sasha.
http://www.romraider.com/forum/viewtopic.php?f=40&t=13725&p=128168#p128168
Found some SSM commands BF, A0, A8, B0, B8.... and 81,83,27?
00026580 push lr
00026582 push R10
00026584 push R9
00026586 push R8
00026588 add3 R10, fp, #-0x2EF8
0002658C ldi8 R9, #0
0002658E ldi8 R8, #0
00026590 bl.s sub_266E8 || nop
00026594 ldub R0, @(4, R10)
00026598 ldi16 R1, #0xBF ; '+'
0002659C beq R0, R1, loc_265E0
000265A0 ldi16 R1, #0xA0 ; 'á'
000265A4 beq R0, R1, loc_265E0
000265A8 ldi16 R1, #0xA8 ; '¿'
000265AC beq R0, R1, loc_265E0
000265B0 ldi16 R1, #0xB0 ; '¦'
000265B4 beq R0, R1, loc_265E0
000265B8 ldi16 R1, #0xB8 ; '©'
000265BC beq R0, R1, loc_265E0
000265C0 ldi16 R1, #0x81 ; 'ü'
000265C4 beq R0, R1, loc_265E0
000265C8 ldi16 R1, #0x83 ; 'â'
000265CC beq R0, R1, loc_265E0
000265D0 ldi8 R1, #0x27 ; ''' || nop
000265D4 beq R0, R1, loc_265E0
000265D8 ldi8 R1, #0x10 || nop
000265DC bne R0, R1, loc_26680
Edited by roadie08
m32r
roadie, you have ubuntu on any of your computers? for the life of me i cannot try to disassemble the .bins into plain text so we can read them.
ive looked at this website which is an evo forum and they have already disassembled the code.
take a look for yourself and see
https://www.evolutionm.net/forums/ecuflash/564101-rom-disassembly-raw-text-file.html
Havent tried that, but onlinedissasembler will probably have similar output.
One thing is that if we can identify where the unique address is for the rom we could use ecuflash and view some stuff in there
I think the ecuid is at 802A to 802E
0000802A .byte 0x91
0000802B .byte 0xFE
0000802C .byte 0x20
0000802D .byte 0x71
0000802E .byte 0
Edited by roadie08
0000802A .byte 0x91
0000802B .byte 0xFE
0000802C .byte 0x20
0000802D .byte 0x71
0000802E .byte 0
I dont think that worked but probably doing it wrong. see if you can use other tuners and get some data off it. Hopefully shooting for a some graph or editable fields
Roadie: Are you digging into 91FE207100?
I have looked at the rom in winols demo but dont understand the table layout...
Also trying to connect directly to the mcu in bootmode but no luck yet.
  • 3 weeks later...
Dont know if I get it into bootmode correctly.
Power on -> pull mod0 high -> pull reset low
Then reset should go high as in normal mode but it does not. I can pull it high but not sure if thats correct.
Any ideas?
  • 1 month later...
