Unilat Posted April 11, 2005 Share Posted April 11, 2005 I've got some pits on my hood that need to be touched up. What should I use to make sure that all waxes, etc are off the spot before applying? Link to comment Share on other sites More sharing options...
OCDetails Posted April 11, 2005 Share Posted April 11, 2005 dish soap would probably do the trick. If you are going to do touch up then I would wash down the entire hood with dish soap and then reapply the products after the paint has had time to dry. Sometimes you can get strange color changing on the edge where you cleaned off product and then reapplied it, so I always try to work on an entire panel if I start doing something. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
DEI99662 Posted April 13, 2005 Share Posted April 13, 2005 If you dont want to wash the whole hood again and the pits are small enough, try washing and using some wax remover before you touch up those pits. Link to comment Share on other sites More sharing options...
