Mr. Sinister Posted March 25, 2010 Share Posted March 25, 2010 To drain all the fluid, I need to remove both drain plugs, the T70 drain and the drain on the oil pan side, correct? Link to comment Share on other sites More sharing options...
Mr. Sinister Posted March 25, 2010 Author Share Posted March 25, 2010 I ended up opening that plug too and another half quart or so came out. It took about 4.1/4.2 quarts to hit the full mark, so I'm guessing I drained it properly. Link to comment Share on other sites More sharing options...
rao Posted March 25, 2010 Share Posted March 25, 2010 You figured it out Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Mr. Sinister Posted March 25, 2010 Author Share Posted March 25, 2010 You figured it out And there were no weird noises on the way to work either! Link to comment Share on other sites More sharing options...
rao Posted March 25, 2010 Share Posted March 25, 2010 You must have used synthetic gear oil Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
Mr. Sinister Posted March 25, 2010 Author Share Posted March 25, 2010 It was Extra-S. It's not synthetic, but it's not readily available either. I'm not sure which criteria holds more weight so I'll have to wait and see if it was good enough. Link to comment Share on other sites More sharing options...
rao Posted March 25, 2010 Share Posted March 25, 2010 Extra-S has a special exemption - it is recommended by the engineers that designed the crappy components that make up the Legacy. Rob IF YOU CARE ABOUT YOUR CAR YOU SHOULD NEVER DRIVE IT Link to comment Share on other sites More sharing options...
integroid Posted March 26, 2010 Share Posted March 26, 2010 It was Extra-S. It's not synthetic, but it's not readily available either. I'm not sure which criteria holds more weight so I'll have to wait and see if it was good enough. Errrr...Extra-S is available at every Subaru dealer in my area. It is what goes into all 6MT trannys. I was using it in my 5MT as well as my 6MT. Link to comment Share on other sites More sharing options...
Darkness of Death Posted March 26, 2010 Share Posted March 26, 2010 i'm pretty sure if i asked for that here, they wouldn't even know what it is. kind of like how the service and parts guys didn't even know what the SI drive does. Link to comment Share on other sites More sharing options...
Mr. Sinister Posted March 26, 2010 Author Share Posted March 26, 2010 Errrr...Extra-S is available at every Subaru dealer in my area. It is what goes into all 6MT trannys. I was using it in my 5MT as well as my 6MT. Lucky you. I called 3/4 dealers in my area and only one knew what the hell I was talking about. I ended up buying 5 quarts from FBP. Link to comment Share on other sites More sharing options...
rs6er Posted April 5, 2010 Share Posted April 5, 2010 I just bought it from them too. $12/qt. Link to comment Share on other sites More sharing options...
bakabakablah Posted May 4, 2010 Share Posted May 4, 2010 I was reading up in the other thread and I just wanted to make sure before I ordered anything but the Extra-S can be used in the transmission AND the rear diff? And that means I'll need to order ~6 quarts of the stuff (4.3 for the transmission and around a quart for the rear diff), correct? Link to comment Share on other sites More sharing options...
rs6er Posted May 4, 2010 Share Posted May 4, 2010 You want to use the Subaru LSD stuff (# k0305y0900) in the rear diff of your Spec B. I just did this. Link to comment Share on other sites More sharing options...
integroid Posted May 4, 2010 Share Posted May 4, 2010 I thought you only had to use the LSD Oil in the rear diffs of the 04/05 MY? Anything newer could use the Extra-S Link to comment Share on other sites More sharing options...
istealfrombums Posted May 4, 2010 Share Posted May 4, 2010 Actually the Subaru LSD stuff is not needed because the rear LSD on the spec B is a sealed unit, the extra-s will be fine. Only the 04-06 STI rear LSD requires the special Subaru LSD fluid. More info is available in the Extra-S cat's meow thread. Link to comment Share on other sites More sharing options...
