do you use the stock inner shim with aftermarket pads
SSpeed
http://i85.photobucket.com/albums/k62/dil222/brakes.jpg
When replacing with the stock brake pads with Hawk aftermarket pads, do you keep the inner shim (the middle one in the picture)?
The only other thread I found was this one:
http://legacygt.com/forums/showthread.php/installing-cobb-street-formula-pads-48268.html?t=48268
Which seemed to have my same problem. What is the purpose of the inner shim if we can go without it?
I tried to check with Hawk just to be sure as well, and just got this response:
Scott –
The shim we put on our pads is designed to run by itself. You could put the outer OE shim on but it might make noise. A lot of times the OE will put multiple shims on to try and turn that specific brake pad. Our shims are a single layer of steel with rubber bonded on each side for insulating and noise reduction.
Thanks,
Todd Miller
  • 6 months later...
