BRP800 Posted March 15, 2010 Share Posted March 15, 2010 My '05 Limited GT wagon I have to push the clutch as hard as I can into the firewall to shift easily into reverse. Yes, I do the 3rd then rev technique in cases. I can't even use a floor matt because the clutch pedal can't go far enough. Only 22,000 miles on car. Would it work if I put 3mm washers under the mounting base into the firewall? This would bring the pedal assembly far enough out to fully engage It should work. Assuming there are not vertical bolts also. Please advise your opinion. Thanks. Link to comment Share on other sites More sharing options...
Jmhm17 Posted March 18, 2010 Share Posted March 18, 2010 bump Link to comment Share on other sites More sharing options...
custom_junky Posted March 18, 2010 Share Posted March 18, 2010 these pedals should require no adjustment, they are hydrualic clutches...you may have a leak in the master or slave cylinder, or might be low on fluid...check these first Link to comment Share on other sites More sharing options...
Jmhm17 Posted March 18, 2010 Share Posted March 18, 2010 The clutches in SRT4's are hydraulic and the pedal is adjustable.. just using that as an example.. Link to comment Share on other sites More sharing options...
custom_junky Posted March 18, 2010 Share Posted March 18, 2010 huh? i've never seen a hydralic clutch that is adjustable, unless the pedals move in and out electronically...that's very interesting... Link to comment Share on other sites More sharing options...
BRP800 Posted March 19, 2010 Author Share Posted March 19, 2010 Amazing that no one had the answer. Even the "expert, certified Subaru Technicians", or in the "Pay for Assistance website." If you'll check the Subaru '05, Transmission Service Manual (book 6) on page CL-23, drawing no. 00042. there's a push rod and adjusting nut inside the firewall. Thanks for the assistance. Link to comment Share on other sites More sharing options...
custom_junky Posted March 21, 2010 Share Posted March 21, 2010 good to know...thanks Link to comment Share on other sites More sharing options...
soobnoob Posted March 21, 2010 Share Posted March 21, 2010 I HAVEN'T seen a hydaulic clutch pedal that couldn't be adjusted lol. If it is anything like other makes/models there should be a locknut on the M/C shaft and you can twist the shaft itself to draw it in or out relative to the M/C. But I agree that you shouldn't have to adjust for normal clutch operation. Check the hydraulic system for leaks. Edit: Got beat to it. Link to comment Share on other sites More sharing options...
scottmcphee Posted August 29, 2018 Share Posted August 29, 2018 Just made this adjustment on my 06 Leggy Back off the 12mm locking nut on the threaded rod, a stubby wrench is needed to get in on it. Then twirled the rod by finger power so as to be backing it away from the clevis pin, the nut riding along with the rod. Then spin the nut back down to tighten it. Now the clutch engagement point for the pedal is an inch or so closer to the floor where we like it better than being so high up near the end of travel. Testing all the things work fine, pedal needs to be fully depressed to start car, cruising gets cut when clutch pedal is touched, etc.. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted September 5, 2018 Share Posted September 5, 2018 My clutch needs this adjustment as well I have to push it all the way to the floor if you move it only like 5 mm up you can start to feel it grabbing. Link to comment Share on other sites More sharing options...
lakestreet Posted October 19, 2018 Share Posted October 19, 2018 Curious about this too, have a stage 2 clutch and the engagement point is right off the floor. I had an RX8 with a hydraulic clutch and you could adjust it. Link to comment Share on other sites More sharing options...
lakestreet Posted October 19, 2018 Share Posted October 19, 2018 Whoops just saw post 9, my apologies. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 19, 2018 Share Posted October 19, 2018 yep it works good Link to comment Share on other sites More sharing options...
