jproy12 Posted November 25, 2010 Share Posted November 25, 2010 Anyone have some news? JP Link to comment Share on other sites More sharing options...
RedFloyd Posted November 25, 2010 Share Posted November 25, 2010 Same "trouble" here. No solutions found tough... subscribed! Link to comment Share on other sites More sharing options...
jasejase Posted November 25, 2010 Share Posted November 25, 2010 my 07 did that. it was the oem winter mats. Link to comment Share on other sites More sharing options...
jproy12 Posted December 7, 2010 Share Posted December 7, 2010 Any update? JP Link to comment Share on other sites More sharing options...
svx6 Posted December 7, 2010 Share Posted December 7, 2010 Mine has the same issue. I thought I was just nitpicky. Link to comment Share on other sites More sharing options...
B-BGTLimited Posted December 7, 2010 Share Posted December 7, 2010 I have this sound as described, only does it after a duration of not touching the brake. I hope to have some time this winter to look around under my dash and familiarize myself with how everything works. I will obviously report back if I find anything. I think I can get this noise from both the clutch and the brake pedal, but I'm not positive on that one. Link to comment Share on other sites More sharing options...
svx6 Posted December 7, 2010 Share Posted December 7, 2010 yeah...it's like..."slack" or something. Link to comment Share on other sites More sharing options...
jproy12 Posted December 7, 2010 Share Posted December 7, 2010 I think I can get this noise from both the clutch and the brake pedal, but I'm not positive on that one. Well I guess I'm not the only one, I have the same thing in my clutch! I honestly have no clue what it is! JP Link to comment Share on other sites More sharing options...
ddude123 Posted January 1, 2011 Share Posted January 1, 2011 Hi-I'm new to this sight and have just purchased my third subaru--2011 legacy sedan--I just hit 1000 miles and the brake system is making a loud annoying click when pedal is depressed. I took it to dealer and the salesman acted like he never heard of the problem. Service manager said it was normal for subaru but I'm not buying that. It is a noise coming from the brake booster or master cyl. If they don't resolve it I am going to collect my work orders and go for lemon law. Other than brake noise it is a great car.Service manager also said that their is no fix for problem. Link to comment Share on other sites More sharing options...
Merc6 Posted January 1, 2011 Share Posted January 1, 2011 I was gonna ask what your mileages are for these cars but it went from 05-11 models. Maybe I just wrote this off as another Subaru quirk. Gonna see if I can create this click/pulse not caused by abs engaging on slippery surface. Saw someone said eat so not clutch shudder/chatter. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
slimjim2 Posted January 2, 2011 Share Posted January 2, 2011 I had the same click at 2 of the four corners. I removed the pads, used brake pad grease at all contact points, and reassembled. All is quiet now. I was able to put my head out of the window and pretty definitively able to determine which wheel was the culprit, but wound up applying grease to all corners just as a preventative. Hope this helps Link to comment Share on other sites More sharing options...
define Posted January 2, 2011 Share Posted January 2, 2011 Ugh, same click here. Just thinking about it bother me. Glad I'm not alone. Link to comment Share on other sites More sharing options...
Merc6 Posted January 3, 2011 Share Posted January 3, 2011 Swapped the pads out and use the spray on disc quiet a while back. I don't "not touch the brakes for a while" cause we have a city of little boy cried woof brake stompers. Other reason is my tune puts my cruising speed foot off gas @ about 37 MPH and these roads are 25 MPH. Can't recreate it either. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
B-BGTLimited Posted January 3, 2011 Share Posted January 3, 2011 I had the same click at 2 of the four corners. I removed the pads, used brake pad grease at all contact points, and reassembled. All is quiet now. I was able to put my head out of the window and pretty definitively able to determine which wheel was the culprit, but wound up applying grease to all corners just as a preventative. Hope this helps Click I have is physically under the dash, it is not a sound coming from any of the calipers. I have still not looked into this since I've been busy over the holidays. Link to comment Share on other sites More sharing options...
Val Demar Posted January 3, 2011 Author Share Posted January 3, 2011 Yup, this thread is specifically about the noise coming from inside the cabin, it is apparently originating from the pedal mechanism or may be the master cylinder. I get 0-noise from the calipers/pads. Link to comment Share on other sites More sharing options...
jproy12 Posted January 4, 2011 Share Posted January 4, 2011 Yea, I still have this noise, and it seems like its also in the clutch pedal, I don't see anything wrong with the car though... Hopefully someone can find out the problem! Its really annoying. JP Link to comment Share on other sites More sharing options...
Guest PeteAWD Posted January 8, 2011 Share Posted January 8, 2011 It's may be the contact relay that actuates the brake lamps. JUST A GUESS. Link to comment Share on other sites More sharing options...
Guest PeteAWD Posted January 8, 2011 Share Posted January 8, 2011 I hear a click when my intermittent wiper are on. It's more pronounced then when the car was new. Link to comment Share on other sites More sharing options...
svx6 Posted January 8, 2011 Share Posted January 8, 2011 It's not the switch. My clutch perl does it too. It almost feels like there is a burr or something unfinished in the metal of the pedal assembly. Link to comment Share on other sites More sharing options...
jasejase Posted January 8, 2011 Share Posted January 8, 2011 not to beat a dead horse, but do you have winter mats in? My clutch pedal clicked constantly with winter mats in. it really sounds like the exact same noise (though different pedal) i actually thought the pedal arm was busted it was so specific. Link to comment Share on other sites More sharing options...
Val Demar Posted January 8, 2011 Author Share Posted January 8, 2011 Nope, no mats. Link to comment Share on other sites More sharing options...
jasejase Posted January 8, 2011 Share Posted January 8, 2011 worth a shot. Link to comment Share on other sites More sharing options...
jproy12 Posted January 8, 2011 Share Posted January 8, 2011 Its not the mats... I have the weathertechs for winter and it still makes the noise, summer I have the OEM legacy mats... I also have the click in my clutch pedal, getting annoyed! JP Link to comment Share on other sites More sharing options...
jasejase Posted January 9, 2011 Share Posted January 9, 2011 the dealer didnt have any idea? seems like it could be common... Link to comment Share on other sites More sharing options...
Val Demar Posted January 9, 2011 Author Share Posted January 9, 2011 Dealers typically don't acknowledge an issue to be a common problem. I had my car repaired on several occasions for "known" problems extensively discussed on these boards but dealer always said it was the first time they saw it. On my complaint about this particular click the dealer said everything was normal. From my experience it always takes an extra effort to prove there is something wrong with the car to Subaru dealers, this gets frustrating, and will be one of the reasons my next car (most likely) won't be a Subaru. Sorry for the off-topic. Link to comment Share on other sites More sharing options...
