Leonardo Posted November 23, 2010 Share Posted November 23, 2010 nope, sold them Link to comment Share on other sites More sharing options...
NSFW Posted November 24, 2010 Share Posted November 24, 2010 Yeah I was asking cause I found one on ebay for cheap and was curious if it would fit. Any ideas on where I could find a 5 speed from a LGT for sale? If you're anywhere near Seattle, PM me. Link to comment Share on other sites More sharing options...
06gtleg Posted December 29, 2010 Share Posted December 29, 2010 I know this thread is old but do you guys know if an 04 sti peddle assembly will bolt up to my car? 06 legacy gt 5EAT Link to comment Share on other sites More sharing options...
Rick Posted December 31, 2010 Share Posted December 31, 2010 I know this thread is old but do you guys know if an 04 sti peddle assembly will bolt up to my car? 06 legacy gt 5EAT They are different part #'s so I would say probably not. Link to comment Share on other sites More sharing options...
Leonardo Posted December 31, 2010 Share Posted December 31, 2010 Just talked to a mechanic here in Puerto Rico that has done the conversion a few times and tells me that the trans crossmember from the 5mt does bolt on without a hitch. Also the speedometer sensors are diferent. He is making me afloat of what he does to compare notes but tranny, driveshaft, rear diff, crossmember and pedal box/clutch reservoir are the main things. Link to comment Share on other sites More sharing options...
06gtleg Posted January 4, 2011 Share Posted January 4, 2011 They are different part #'s so I would say probably not. Thanks Link to comment Share on other sites More sharing options...
gotsugg Posted January 9, 2011 Share Posted January 9, 2011 It's been a while since I read this entire post so this might have been asked before. Is a 5mt a 5mt? Meaning, is there any difference between a 5mt in a 2.5I, GT, OB, OBXT? I would guess that the 5mt across the entire Legacy platform is the same but I could be wrong. Also, Is there a place I can look up and compare final drive ratios and gearing? Has anyone seen a thread that shows this in detail? Thanks Link to comment Share on other sites More sharing options...
frank_ster Posted January 9, 2011 Share Posted January 9, 2011 this is for 2005 stuff .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted January 10, 2011 Share Posted January 10, 2011 Legacy Specs Outback Specs Trans specs are all in there. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
gotsugg Posted January 10, 2011 Share Posted January 10, 2011 Great info. Thank D. Link to comment Share on other sites More sharing options...
Leonardo Posted April 15, 2011 Share Posted April 15, 2011 Legacy Specs Outback Specs Trans specs are all in there. Wait, the auto in the outback has a higher final drive gear than the one in the GT? Any way, bum ping for new info on a way around the error code. I might start saving parts to make this happen. Link to comment Share on other sites More sharing options...
Rick Posted April 15, 2011 Share Posted April 15, 2011 Wait, the auto in the outback has a higher final drive gear than the one in the GT? Any way, bum ping for new info on a way around the error code. I might start saving parts to make this happen. The only error code that you will see displayed will be a can bus comunication error. All other codes can be ignored using ecuflash or romraider. I've been trying to source all the parts needed to change my speedometer cluster and get rid of the can bus error, but everyone wants in excess of over a grand for those parts. IMO not worth it, the car runs great as it is. Link to comment Share on other sites More sharing options...
Leonardo Posted April 15, 2011 Share Posted April 15, 2011 (edited) What parts do you need? I have seen a lot of part-outs lately! I might start with the clutch line and cylinder. Also, would switching the transmission crossmember from the auto to the manual work if I could fin one instead of modifying the auto one? EDIT: Nevermind, found that it will not work. Will have to get another cross brace from a wrecked 5EAT and have it modified to minimize down time. We can then make that a floating brace for others tacking this project. Edited April 15, 2011 by Leonardo Link to comment Share on other sites More sharing options...
Leonardo Posted April 15, 2011 Share Posted April 15, 2011 see attachment for conversion ... for can comunication .. Were all the variations of this tried? Unplugging the harness from the TCU CAN Joint Connector and jumping them taking that part out of the electrical system? Might have something to do that in the manual car you don't have that in the lop at all and just the wire running from ABS Module to the ECM CAN Joint Connector. Wonder how different is the actual harness. Would be worth just getting one to compare without needing to swap, just modify as needed. Link to comment Share on other sites More sharing options...
Rick Posted April 15, 2011 Share Posted April 15, 2011 What parts do you need? I have seen a lot of part-outs lately! I might start with the clutch line and cylinder. Also, would switching the transmission crossmember from the auto to the manual work if I could fin one instead of modifying the auto one? EDIT: Nevermind, found that it will not work. Will have to get another cross brace from a wrecked 5EAT and have it modified to minimize down time. We can then make that a floating brace for others tacking this project. I need the following from the same 05 or 06 LGT: 5mt gauge cluster 5mt ecu ignition switch with key and key fob key fob antenna inside steering column (I think) All this to hopefully be able to use a manual gauge cluster, and get rid of that can bus error. To be completely honest I just don't think its worth it. If anyone has an extra 5mt gauge cluster I would be interested in just trying to switch the face plates. Link to comment Share on other sites More sharing options...
Leonardo Posted April 15, 2011 Share Posted April 15, 2011 Post in this thread to see: http://legacygt.com/forums/showthread.php/nm-2005-legacy-gt-5-speed-partout-155457.html Link to comment Share on other sites More sharing options...
Rick Posted April 15, 2011 Share Posted April 15, 2011 Post in this thread to see: http://legacygt.com/forums/showthread.php/nm-2005-legacy-gt-5-speed-partout-155457.html He's not selling the ecu. Link to comment Share on other sites More sharing options...
Leonardo Posted April 16, 2011 Share Posted April 16, 2011 We at least need a cluster to start there. Then keep getting the parts as they come available. I just want to get this done the proper way since the mechanical works out great. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 16, 2011 Share Posted April 16, 2011 ebay. Clusters pop up once in a while. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Rick Posted April 16, 2011 Share Posted April 16, 2011 You can't just swap one gauge cluster for another because of the immobilizer. The gauge cluster, imobilizer, ignition switch, key, and ecu have to come from the same donor vehicle. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 16, 2011 Share Posted April 16, 2011 You can't just swap one gauge cluster for another because of the immobilizer. The gauge cluster, imobilizer, ignition switch, key, and ecu have to come from the same donor vehicle. Can't you buy a Subaru service tech a case of beer and swap the cluster in the parking lot, then have him write a new code and see if it takes? When unclemat got hi different ECU, he just plugged it in in the parking lot and then dealer SSM set a new immobilizer code... [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Leonardo Posted April 16, 2011 Share Posted April 16, 2011 Hmm! Link to comment Share on other sites More sharing options...
Rick Posted April 17, 2011 Share Posted April 17, 2011 Can't you buy a Subaru service tech a case of beer and swap the cluster in the parking lot, then have him write a new code and see if it takes? When unclemat got hi different ECU, he just plugged it in in the parking lot and then dealer SSM set a new immobilizer code... I guess you could. I don't know any of the service guys at my local Subaru stealership though. I've only taken my car there on one occasion to fix an axle leak I didn't have time to fix, and they wanted no part of it. Apparently my 5mt swapped car is an abomination. Link to comment Share on other sites More sharing options...
Leonardo Posted April 18, 2011 Share Posted April 18, 2011 I already on my way for this as I got a clutch master cylinder and both lines to the slave. Got to start somewhere! Link to comment Share on other sites More sharing options...
ESP Dyno Posted April 19, 2011 Share Posted April 19, 2011 I find the error code kind of comforting. Embrace it I have a spare manual cluster and a manual ABS module of out an 05 LGT. I guess I could donate it to a good cause... www.EnhancedStreetPerformance.com www.facebook.com/EnhancedStreetPerformance Link to comment Share on other sites More sharing options...
