Matty2Hotty Posted February 26, 2010 Share Posted February 26, 2010 Have a 01 lgt, going to get a reader for my Subaru. What I the huge difference in scanner and code reader? What should I get and why? Just going to mod a little and get some codes due to hf cats. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted March 1, 2010 Share Posted March 1, 2010 this question is vague, you're going to have to post specific products that you are considering On the search for a new DD... Link to comment Share on other sites More sharing options...
papa g Posted March 1, 2010 Share Posted March 1, 2010 Code readers will generally just read and reset CEL codes. OBD scanners will read data from the ECU and clear codes. Scanners can give you good info about how your car is running if there are problems depending on the quality of scanner you get. BE committed to DO what it takes to HAVE more of what you want in your life!!! Link to comment Share on other sites More sharing options...
NSFW Posted March 1, 2010 Share Posted March 1, 2010 Generic code readers are a waste of money for what you're going to do. Knowing what codes you have doesn't help much, you'll also want to disable one or more of them depending on what mods you do. And you'll want to retune the ECU, or get it retuned, for those mods to work to their full potential without damaging the car. And you'll want to log a few things (at a much faster rate than generic ODB2 provides) to find out of the engine is healthy and/or troubleshoot problems. Click here for more info: http://www.romraider.com/forum/topic5320.html Link to comment Share on other sites More sharing options...
Polo08816 Posted December 28, 2016 Share Posted December 28, 2016 How do those options compare to Subaru Select Monitor 3? Would you need a VXDIAG hardware? Link to comment Share on other sites More sharing options...
