The Unofficial 05-06 LGT 2.2k .5w Resistor UP Pipe Install CEL FIX
It's not the sensor that's the worrisome turbo-damaging failure part; it's the cat in the OEM uppipe. We're replacing the UP with one that doesn't have a cat, and no EGT sensor either, hence no bung that requires plugging. It doesn't make a whole lot of sense to remove the EGT sensor but keep the stock UP.
  • Replies 123
  • Created
  • Last Reply
Top Posters In This Topic
Scott FYI I have replaced the up with an INvidia. It has a bung for the EGT. I found a M12x1.25 bolt. But the shortest one I could find is about 3" long. I will cut it down to about an inch and hope I can get the threads cleaned up enough.
Keep it as short as possible so that at the end of its "run", it's flush with the inside of the pipe. Otherwise - too short, or too long, you have turbulence, and potential for heat-cycle leak. Probably not a lot of turbulence, but anything that disrupts the laminar flow to the turbine isn't helpful.
Likewise, with the latter length, sticking into the gas flow gets the bolt heated more than necessary and can cause expansion/contraction that will cause the bolt to work loose and leak.
  • 2 years later...
Hey OP... your "Insert them in your EGT sensor plug receptacle as seen below" picture is missing
catless up-pipe in the mail
http://cdn.smosh.com/sites/default/files/ftpuploads/bloguploads/1113/fabulous-kid-white-dance.gif
  • 3 months later...
Hey guys, I have a question pertaining to this old thread. Say I cannot find a catless uppipe. Could I rod out the stock uppipe and cap the sensor hole, then do the resister mod? Would that obtain the same result? I would prefer to find a used factory catless uppipe, but after several days of looking on the Nasioc classified page, I cannot find one for sale (ok, there is one, but it's an old ad, and the seller has not responded to PM).
H2OSB
H2OSB
Technically yes, but you would have to be extremely careful that every last bit of material is removed because anything that rattles loose later is taking a trip through your turbo. I don't think the risk is worth it
  • 2 weeks later...
This! It's simply not worth the risk. Also there are health hazards with breathing in cat dust.
05 LGT 16G 14psi 290whp/30mpg (SOLD)
12 OBP Stock 130whp/27mpg@87 Oct
00 G20t GT28r 10psi 250whp/36mpg
22 Ascent STOCK
  • 9 months later...
I got a question regarding with this thread.
I have 2005 LGT Limited 5AT 136K miles bone stock, and about to replace the uppipe before something goes wrong and destroys the turbo.
I read something online says there's a downside using resistors. It could lead to some electrical failure later on like the CRUISE CONTROL will quit working eventually. Is this true?
They highly recommend using AP to flash it, but I really don't need an AP since I don't do a lot of mods. Any thoughts ???
Thank you in advance!
Most that have run the 2.2k, say to make sure it is secure in the connector, duct tape.
IMO you want a Cobb AP at least stage 1 tune, its how these cars should have come from the factory. It's also safer for the engine.
Engine Build - Click Here
There is no downside to using the resistor, but there is a downside to not using one.
When the EGT sensor is removed and no resistor is installed, it throws a CEL. This CEL can be blocked, but blocking a CEL does not change how the ECU reacts to a missing sensor.
The 2.2kOhm resistor tells the ECU that the EGT sensor is reading something like 800 degrees. This is a happy temperature and the ECU does nothing extra. With a missing sensor, the ECU will reference the highest temperature in the EGT tables and use a fuel trim to adjust. If you are un-tuned, or your tuner did not modify this table, it will mess up your fuel trims, possibly causing the engine to run funny or cause poor fuel economy.
By installing a $1 resistor, you prevent second guessing your tuner and stupid fueling issues related to a removed component.
I have never seen any reported cases of the resistor mod causing problems of any kind.
(Updated 8/22/17)
2005 Outback FMT
Running on Electrons
Thank you both !
I will definitely consider getting an AP, but for the mean time i'll stick with the resistors.
Found a Cobb AP V2 the other day locally for $200 and seller says its unmarried. When I got there and check its married to 2013 Subaru WRX. Prolly stolen or something and he doesn't know what he was talking about. He tryna sell it to me for $100, but that's not gonna do me any good. So I just left with disappoinment :/
  • 4 months later...
  • 4 months later...
  • 2 months later...
  • 10 months later...
Can anyone tell me how and why the specifics were determined to using 2.2k ohm .5 watt resistor?
I'm looking to use this method in another vehicle. I swapped seats. The originals had a side airbag. The new ones do not have this airbag but are from the same model vehicle. After installing the new seats the plugs all plug in but there is not yellow plug (airbag) to plug into the harness on the car side. Therefor the vehicle thinks that the seat airbag sensor is not plugged in. and a light on the dash is now displayed.
I was thinking of using this method to trick the sensor into thinking its plugged in. How do I know that I should use 2.2k ohm .5 or a different spec?
The sensor on the up pipe is a temperature sensor that provides temp data to the ECU. The ECU knows that a certain range of voltage is "good" so therefore won't produce a CEL. 2.2k ohm of resistance put that voltage in the correct range, tricking the ECU into thinking there is an operational sensor.
Now, for your airbag sensor, it's hard to say what the ECU is expecting. So that's the million dollar question, what resistor. I have read both a 2.2 ohm and 3.3 ohm (NOT 2.2k or 3.3k ohm which is 2200/3300, but 2.2/3.3) resistors are correct. I guess it depends on the car, but the concept is exactly the same as this. I'd suggest searching "seat airbag resistor" for your particular car
Edited by nonsense
Your saying you've read that its a 2.2 or 3.3 ohm for airbag sensors? or in this statement are you referring to the up pipe temp sensor from this original thread?
Yes, I've seen sever youtube videos that reference 2.2 or 3.3 ohms. It's not uncommon when people put race seats in a car that have seat airbags
just search "seat airbag sensor resistor" for your specific car
