SBT Posted July 26, 2012 Share Posted July 26, 2012 Took mine out when I upgraded the UP, and never bothered with the resistor fix. Turned it off with the tune. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted July 27, 2012 Author Share Posted July 27, 2012 There is no real need for a resistor fix as it can be turned off with the tune. I mentioned that I did the resistor in a thread and ended up getting PM'd so consistantly that I wrote a thread so I could just give the link Random but true. Link to comment Share on other sites More sharing options...
mwiener2 Posted July 27, 2012 Share Posted July 27, 2012 There is no real need for a resistor fix as it can be turned off with the tune. As I just said a few posts back, you eliminate the CEL, but the ECU still delays the OL/CL transition. The proper modification is to remove the sensor and install the resistor. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
SBT Posted July 28, 2012 Share Posted July 28, 2012 (edited) As I just said a few posts back, you eliminate the CEL, but the ECU still delays the OL/CL transition. The proper modification is to remove the sensor and install the resistor. First I recall understanding that. Me thinks I'll do this as soon as I get back home. Would not having this fix have any effect on how the car runs, if tuned without it? What effect would it have to now install it? Edited July 28, 2012 by SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
mwiener2 Posted July 28, 2012 Share Posted July 28, 2012 It affects time delays and minor table references. It should be independent of the tune. So adding the resistor later shouldn't mess up a tune. And sorry, I didn't say it in a few posts back, it was in a different thread that should probably be merged with this one. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted July 28, 2012 Author Share Posted July 28, 2012 I reread your posts 3 or 4 times trying to figure out what you were talking about. Link to comment Share on other sites More sharing options...
Gex Posted August 7, 2012 Share Posted August 7, 2012 (edited) So.... I just went and got 2.2k ohm resistor in a 1/4W. I take it I bought the wrong one and need 1/2W? No big deal as the car is still in pieces just confirming that I cannot use this. Got the .5w ones. No need to take chances Edited August 7, 2012 by Gex Link to comment Share on other sites More sharing options...
mwiener2 Posted August 8, 2012 Share Posted August 8, 2012 doesn't matter which My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
legacy360 Posted August 11, 2012 Share Posted August 11, 2012 Even though I've been going 6 months with the code disabled, went ahead and threw in the resistor. Link to comment Share on other sites More sharing options...
SBT Posted August 11, 2012 Share Posted August 11, 2012 Notice any difference(s)? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted August 11, 2012 Share Posted August 11, 2012 I'm planning to just cut the connector to the EGT sensor, pull the wires out of that and solder/crimp the resistor into the wire locations, and then RTV seal that end to protect it from wet and exposure. Once the RTV is dry, I'll plug the whole assembly into the femail receptacle and call it a day. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
legacy360 Posted August 11, 2012 Share Posted August 11, 2012 Not quite yet, haven't had enough seat time. But I'm definitely going to be keeping an eye on it. Link to comment Share on other sites More sharing options...
bg. Posted September 4, 2012 Share Posted September 4, 2012 doesn't matter which So I have a 1/4W 2.2K ohm resistor available locally.... nothing in a 1/2W.. this does not make a difference? I can use the 1/4W one right? Thanks Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted September 4, 2012 Author Share Posted September 4, 2012 doesn't matter which Link to comment Share on other sites More sharing options...
SBT Posted September 4, 2012 Share Posted September 4, 2012 I was surprised, to say the least, at the immediate improvement. Car feels better all the way around, especially at low rev driving, where previously it always felt like it was running rich and chugging, now it feels smooth and linear. Any possibility that the resister has any effect on the fueling at this level? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
slim101 Posted September 8, 2012 Share Posted September 8, 2012 (edited) noob question, if i get a catless uppipe do i need a tune. still searching for my cobb ap but i have a catless now. edit nvm i found it. Edited September 8, 2012 by slim101 searched and found answer. Link to comment Share on other sites More sharing options...
SBT Posted September 8, 2012 Share Posted September 8, 2012 Took the car out for a longer 50+ mile drive today. Lots of stop-and-go, some cruising, but most was idling and low speed. 27mpg - so much smoother and the throttle transitions are definitely improved. Wish I had done this way-back when. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Mortal2None Posted September 9, 2012 Share Posted September 9, 2012 Took the car out for a longer 50+ mile drive today. Lots of stop-and-go, some cruising, but most was idling and low speed. 27mpg - so much smoother and the throttle transitions are definitely improved. Wish I had done this way-back when. I have mine routed in post turbo on my AVO DP since the T/S install. So the car will run better after deleting it? I figured it probably was better to leave it in since I had the ability to do so. (Guess I was wrong as usual) Link to comment Share on other sites More sharing options...
Mortal2None Posted September 9, 2012 Share Posted September 9, 2012 I have mine routed in post turbo on my AVO DP since the T/S install. So the car will run better after deleting it? I figured it probably was better to leave it in since I had the ability to do so. (Guess I was wrong as usual) Actually scrap what i said. I took a look and it is not the EGT sensor. It is the front O2 sensor that was routed to the bellmouth on my DP? (The plug next to the ETG with the four wires) The dealer that did my T/S conversion must have done the resistor fix when they did the swap. (The 2 wire connector is wrapped in tape) Link to comment Share on other sites More sharing options...
SBT Posted September 9, 2012 Share Posted September 9, 2012 Is there no O2 sensor bung in the TS piping? Find it strange that it's post turbo (for the 1st one). - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
dingbang Posted September 9, 2012 Share Posted September 9, 2012 Yeah, there is no pre-turbo O2 sensor bung on the Jdm t/s oem header/up-pipe...I found it quite odd Link to comment Share on other sites More sharing options...
Mortal2None Posted September 9, 2012 Share Posted September 9, 2012 Yeah, there is no pre-turbo O2 sensor bung on the Jdm t/s oem header/up-pipe...I found it quite odd Yup as DB said, on both the VF38 and VF37/36 T/S no bung in the up. Link to comment Share on other sites More sharing options...
Snowferno Posted September 13, 2012 Share Posted September 13, 2012 This will come in handy this weekend when I install my UP/DP,and turbo Link to comment Share on other sites More sharing options...
HellShadow70 Posted October 21, 2012 Share Posted October 21, 2012 :)Thank you for the fix.my car left me on the way to work on a Saturday on 95. south bound under the buildings at the foot of the GW Bridge. It Just Shut Down (on The Center Lane:icon_cry:) And I Was Stranded It Was Scary with all the cars screeching in the back.:mad:I got my ap from my bag and got the code. then i reset the ecu but only could do 15 MPH. if i did more it would shut off. i Was Able to get to my Friends shop on Webster av. After 12 shut downs. got on the PC and Found this Thread. To Bad Radio Shack Was Closed At 8:00am:lol: But After Waiting for it to open i was able to get it running Normal Again. Thank You. I Will Remove The Sensor and cap my Cobb Up Pipe. Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted October 21, 2012 Author Share Posted October 21, 2012 Wow my thread not only helped someone but saved someone from getting stuck? Funny how its the little things sometimes that are the most useful. Pleased I could help. Link to comment Share on other sites More sharing options...
