what Posted January 13, 2010 Share Posted January 13, 2010 Hey folks, well I used to live here and I am back visiting in Sumter and found some problems with my LGT. I have a stripped bolt on my Perrin TMIC and on my turbo housing. Some mechanic totally screwed this up in the past and I had no idea until I just discovered the problems. Anyone know the closest performance shop that can work on Subies, or have turbos, TMIC? I am sure I could order the stock stuff but I was planning on upgrading anyways but this is on rather short time. I was supposed to drive back up to Ohio Friday but may be staying here longer till I get this stuff fixed. If any of you have any advice or parts, used turbo, TMIC, even stock stuff I definitely am in need. Thanks Link to comment Share on other sites More sharing options...
what Posted January 14, 2010 Author Share Posted January 14, 2010 I got a few suggestions that I think will work. So I will be working on these and probably heading back up without having to buy all new stuff. I am pretty sure I will need to buy a new intake hose though going to the intake manifold. That one keeps coming apart, I think the Subaru dealer actually has that in stock. Link to comment Share on other sites More sharing options...
smitty Posted January 14, 2010 Share Posted January 14, 2010 Is the bolt itself stripped or threads on the turbo/tmic? Im assuming you mean the threads on the parts themselves. You could probably use a helicoil to rethread the items and get new bolts that will match the new threads. On the turbo and tmic, this should be a pretty easy process. Link to comment Share on other sites More sharing options...
what Posted January 14, 2010 Author Share Posted January 14, 2010 The threads on the turbo housing are stripped out. I will have to look into a helicoil. I worked on it today and hopefully got it fixed. I got a new intake hose from the Subaru dealer, and ended up getting a longer Hex head bolt and put a nut on the bottom of it. It was a tremendous amount of fun trying to get the nut on it with no room to reach down there, so I ended up making a tool with a fork and a crescent wrench and was able to get the nut on and tightened. I dont have any tools with me here so I had to buy some and make due with what I had available. Link to comment Share on other sites More sharing options...
