Urbanrunner Posted January 4, 2010 Share Posted January 4, 2010 I have a 2008 Subaru Legacy SE. When i bought the car it came with just your plain old rear view mirror. Since i have owned the car, i have always wanted a auto dim mirror. I finally came across one, but am curious, since i do not already have a powered mirror, will all i need is the 12 inch harness? Has anyone tried this install before. I know Subaru can do it, i just do not want to pay them an arm and a leg to install a mirror if it is really not that difficult. Thanks in Advance! Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 4, 2010 Share Posted January 4, 2010 You'll need the mirror, harness, and the little plastic cover to hide the harness. I switched out my auto-dimming mirror for a homelink one and it less than thirty minutes with pictures taken along the way. Installation would be practically the same if I had a plain mirror. Link to comment Share on other sites More sharing options...
timmahh Posted January 4, 2010 Share Posted January 4, 2010 Super easy. The car is pre wired for it, you just replace the mirror, take down the map lights, locate the harness up there, plug in the cable from the mirror to the harness, then put the wire cover between the mirror and the headliner so it looks nicer, test mirror, put map lights back up. Link to comment Share on other sites More sharing options...
SCSpecB Posted January 5, 2010 Share Posted January 5, 2010 ^yah super easy, I put one in my WRX. Took literally 5 minutes. Link to comment Share on other sites More sharing options...
Urbanrunner Posted January 5, 2010 Author Share Posted January 5, 2010 Thanks guys, I figured it could not be to hard, but wanted to make sure since the car is still under warranty. I have the mirror and I ordered the harness, but i do not have the little plastic cover......do you know where i can find one, or can it be oredered through Subaru? Link to comment Share on other sites More sharing options...
Urbanrunner Posted January 5, 2010 Author Share Posted January 5, 2010 so no one knows where to find a tiny plastic piece? I guess i will have to call Subaru and ask them what they think....if not i will have to go to junk yards in the spring! Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 5, 2010 Share Posted January 5, 2010 so no one knows where to find a tiny plastic piece? I guess i will have to call Subaru and ask them what they think....if not i will have to go to junk yards in the spring! Try contacting FredBeansParts here on the forums. IIRC, there was a part number for it, but I'd have to check the installation instructions to see what the number was. Link to comment Share on other sites More sharing options...
keka_u92 Posted January 17, 2010 Share Posted January 17, 2010 Does anyone know if I can just buy the harness and cover without mirror? Thanks Link to comment Share on other sites More sharing options...
natedog Posted January 17, 2010 Share Posted January 17, 2010 take it to the dealership say i+ fell off and you cant find where it went bet they would just order a new one and install it warrantys can go the mile Link to comment Share on other sites More sharing options...
B-Power-B Posted January 17, 2010 Share Posted January 17, 2010 I also have had some luck with homelink.com (never order parts but with other issues)I once made the mistake of asking a dealer how to program the homelink.... Took 5 mins from homelinks website. Link to comment Share on other sites More sharing options...
Urbanrunner Posted January 21, 2010 Author Share Posted January 21, 2010 You can order just the harness, and you can order just the plastic piece, or at least i could from my local dealer. Oh and the mirror took all of 5 mins to replace....plugin for the harness was right above map lights once removed. THANKS GUYS! Any one know if side mirrors with blinkers can be swaped into a 2.5i SE with no modification? Link to comment Share on other sites More sharing options...
keka_u92 Posted January 22, 2010 Share Posted January 22, 2010 You can order just the harness, and you can order just the plastic piece, or at least i could from my local dealer. Oh and the mirror took all of 5 mins to replace....plugin for the harness was right above map lights once removed. THANKS GUYS! Any one know if side mirrors with blinkers can be swaped into a 2.5i SE with no modification? How much was it? Link to comment Share on other sites More sharing options...
Urbanrunner Posted January 22, 2010 Author Share Posted January 22, 2010 harness was $12.00, plastic wire cover was $2.00 or $2.50.. Thats it, and i only paid like $30.00 for the mirror....it was nice, now i want to install heate seats, fog lights, side mirrors with blinkers and two OEM subs. I just need to know of the things i want to do, which can i do in my 08 2.5i SE! Link to comment Share on other sites More sharing options...
keka_u92 Posted January 23, 2010 Share Posted January 23, 2010 harness was $12.00, plastic wire cover was $2.00 or $2.50.. Thats it, and i only paid like $30.00 for the mirror....it was nice, now i want to install heate seats, fog lights, side mirrors with blinkers and two OEM subs. I just need to know of the things i want to do, which can i do in my 08 2.5i SE! Hi, thanks for your reply. I just called my local dealer and first of all he said I must get the whole package with the mirror because as an accessory it is not sold separately. After I have mentioned that I knew someone who bought the harness and cover separately he found something for $44 harness and $4 cover. Do you think it's possible for you find out the part # of harness and cover? I would appreciate it. I bought this mirror on eBay for $40, and now realize I'm going to spend $100 just to install it Link to comment Share on other sites More sharing options...
B-Power-B Posted January 24, 2010 Share Posted January 24, 2010 Hi, thanks for your reply. I just called my local dealer and first of all he said I must get the whole package with the mirror because as an accessory it is not sold separately. After I have mentioned that I knew someone who bought the harness and cover separately he found something for $44 harness and $4 cover. Do you think it's possible for you find out the part # of harness and cover? I would appreciate it. I bought this mirror on eBay for $40, and now realize I'm going to spend $100 just to install it Is the mirror a Subaru part? A lot of the mirrors are 3rd party and you might be able to cut out the middle man and get it direct from the company. Just an idea Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 24, 2010 Share Posted January 24, 2010 Is the mirror a Subaru part? A lot of the mirrors are 3rd party and you might be able to cut out the middle man and get it direct from the company. Just an idea I believe they're made by Gentex. Link to comment Share on other sites More sharing options...
Urbanrunner Posted January 24, 2010 Author Share Posted January 24, 2010 i went to the dealer....the mirror i got was from a junk yard with the original harness chopped. I got the harness and the plastic piece seperate. Here is the part number for the harness for a Compass mirror with auto dim mirror (NOT HOMELINK)= H501SXA120. The plastic piece has yet to arrive...will let u know when it does! Harness was $12.50, plastic piece was $2.00! Link to comment Share on other sites More sharing options...
