TURBOthat Posted January 1, 2010 Share Posted January 1, 2010 So the other day I bought a front and rear sway bar kit from Rallitek. I installed them and after I finished I went out to drive the car and whenever i turn to the right it makes a popping sound in the front left. As if the weight of me turning the car to the right is rubbing something in the left...any suggestions?? Link to comment Share on other sites More sharing options...
JoeFromPA Posted January 1, 2010 Share Posted January 1, 2010 Re-tighten your endlinks. Had the same thing happen to me, I had a loosen end-link. Link to comment Share on other sites More sharing options...
Bbc84 Posted January 1, 2010 Share Posted January 1, 2010 Re-tighten your endlinks. Had the same thing happen to me, I had a loosen end-link. +1 same thing on my LGT, loose rear endlink on 1 side. Link to comment Share on other sites More sharing options...
TURBOthat Posted January 1, 2010 Author Share Posted January 1, 2010 Thanks! I'll try that when I get back home Link to comment Share on other sites More sharing options...
cseagle08 Posted January 3, 2010 Share Posted January 3, 2010 We had this noise appear on my friends Impreza after replacing the roll bars, it had completely broken the end links on the driver side. Shoulda guessed the tiny factory ones wouldn't hold a 25mm bar. Link to comment Share on other sites More sharing options...
qikslvr Posted January 3, 2010 Share Posted January 3, 2010 If you are using stock endlinks; the swivel balls have a tendency to spin when you are tightening them. I can't remember exactly, but you can get a hold of them with a wrech or pliers to hold them while tightening the nuts. Let's kick this pig! Link to comment Share on other sites More sharing options...
TURBOthat Posted January 10, 2010 Author Share Posted January 10, 2010 Hey thanks guys! I tightened one of the endlink bolts and it's all good! However, Whenever I go over a bump theres this awful squeaking noise in the rear, I'm thinking it's possible the struts?? Link to comment Share on other sites More sharing options...
Mr. Sinister Posted January 10, 2010 Share Posted January 10, 2010 Hey thanks guys! I tightened one of the endlink bolts and it's all good! However, Whenever I go over a bump theres this awful squeaking noise in the rear, I'm thinking it's possible the struts?? Did you grease the bushings? Link to comment Share on other sites More sharing options...
Bbc84 Posted January 10, 2010 Share Posted January 10, 2010 did you grease the bushings? +1 Link to comment Share on other sites More sharing options...
PineyLGT805 Posted January 11, 2010 Share Posted January 11, 2010 Grease your Bushings GREASTONNNNNNNNNNNNNNNNNNN Link to comment Share on other sites More sharing options...
