coldradio1 Posted December 29, 2009 Share Posted December 29, 2009 So I've been trying my hardest to pick out a set of wheels and I think I've narrowed it down two sets. The first set I'm not worried about. 8.5" and a reasonable offset. But, the other set is 18x9.5 et 38 and I'm kinda worried about fitment. I checked out the wheel fitment guide skicky thread and +38 seems to be the optimum offset but the tire recommendations seem a bit off to me. I don't see how you could fit 255s without rolling the fenders. I don't mind running negitive camber and I don't mind rolling my fenders, however I really do not want to pull my fenders. I hate the way pulled fenders look and that is that. I know Mr. Cakes old wheels had the same offset and specs as the wheels I'm considering. In this pic of his car, I can't tell if his fenders are pulled or not. I know they are rolled, but pulled I'm not sure. http://i598.photobucket.com/albums/tt70/roadrace3/IMG_6335.jpg I hope he doesn't mind me using his car as an example. The second issue is the tire choice. I know I can run 235/40 tires and have the same stretch as above. But, could I run 225/45 tires and have a little extra room to prevent fender pulling? Any advise is greatly appreciated. BTW, I'll be running coils and am planning on running low. Link to comment Share on other sites More sharing options...
BrownBoy Posted December 29, 2009 Share Posted December 29, 2009 Rolling AND pulling will be absolutely necessary if you want to run lower and the wheels at the stated specs. Link to comment Share on other sites More sharing options...
rurouni_x Posted December 29, 2009 Share Posted December 29, 2009 I have the same wheels on 255.35.18's extensive fender modificaton is needed, roll, pull, and some cuting. Also it depends on haow low you want to go and on what kind of suspension. Link to comment Share on other sites More sharing options...
kw02webe Posted December 29, 2009 Share Posted December 29, 2009 i have 225/40/18x8 on stock suspension and plan on lowering. it looks like it will fit just gotta make sure u use springs that could lower it just enough so u dont need to do too much work. Link to comment Share on other sites More sharing options...
0verboost Posted December 30, 2009 Share Posted December 30, 2009 I have had 18x9.5 +30 with 225/40/18 and definitely needed to do some pulling. Here is a pic of the 18x9.5 setup http://farm3.static.flickr.com/2597/4167895905_8c89a57a45_o.jpg Here is a pic of my current setup on my car with 18x9 +30 235/40/18 http://farm5.static.flickr.com/4023/4227238772_8683959734_o.jpg Link to comment Share on other sites More sharing options...
coldradio1 Posted December 31, 2009 Author Share Posted December 31, 2009 overboost. Do you think that a 18x9 et35 would need pulling? Link to comment Share on other sites More sharing options...
bosco Posted December 31, 2009 Share Posted December 31, 2009 http://www.legacygt.com/forums/showthread.php?t=4426 Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
coldradio1 Posted December 31, 2009 Author Share Posted December 31, 2009 http://www.legacygt.com/forums/showthread.php?t=4426 Thanks man, but I've already looked at that as said in the OP. Link to comment Share on other sites More sharing options...
0verboost Posted January 2, 2010 Share Posted January 2, 2010 overboost. Do you think that a 18x9 et35 would need pulling? Depends on the height you want it at. I had already pulled the fenders awhile back and it was needed for as low as it used to be. You might get away without pulling the fenders if you are at a good height. Link to comment Share on other sites More sharing options...
derffred Posted February 15, 2010 Share Posted February 15, 2010 Bump, I'm debating wide wheels as well. 18x8.5 with the correct sized tires (don't want to stretch the sidewalls). I'm lowered on Tokico Struts/Swift Springs. Any assistance would be great. Link to comment Share on other sites More sharing options...
whitetiger Posted February 15, 2010 Share Posted February 15, 2010 ^you will want a +48 or less offset and you can fit 245/35/18 with a moderate fender roll. if you want to fit a 255/35/18 tire you may need a +45 offset and more of a roll and lots of camber. Link to comment Share on other sites More sharing options...
derffred Posted February 15, 2010 Share Posted February 15, 2010 You know any reputable shops in North Jersey to roll fenders? Link to comment Share on other sites More sharing options...
brooklyngenius Posted February 18, 2010 Share Posted February 18, 2010 If you cant tell that Mr Cakes fenders are pulled then how can you say you dont like it? mr cakes. rurouni, overboost, and myself (like we are the real low offset crew or something) all have rolled pulled frnders and frankly unless you point it out or know you dont notice theyve even been pulled.http://i20.photobucket.com/albums/b240/brooklyngenius/Legacy/DSC_0315.jpg useless signature line where i cant mention my sponsors "First Bagged BL5!" Link to comment Share on other sites More sharing options...
super-roo17 Posted March 6, 2013 Share Posted March 6, 2013 ^you will want a +48 or less offset and you can fit 245/35/18 with a moderate fender roll. if you want to fit a 255/35/18 tire you may need a +45 offset and more of a roll and lots of camber. im only looking to go with a 18x9 with a 40 et. but according to the thread that was pasted above, i could run a 235 35 and be fine?? im looking to drop an 1.5". i know i will have to roll but how about pull?? or any other where and tear?? answers please!! Link to comment Share on other sites More sharing options...
SoMD_GT Posted May 21, 2018 Share Posted May 21, 2018 So on stock height can you run a 18x9.5 +35 with no problems? Link to comment Share on other sites More sharing options...
jrho Posted May 21, 2018 Share Posted May 21, 2018 So on stock height can you run a 18x9.5 +35 with no problems? depends on your tire size really. I ran 18x9.5 et38 with 235/40/18 tires before I lowered my car and i didn't have any rubbing issues Link to comment Share on other sites More sharing options...
SoMD_GT Posted May 22, 2018 Share Posted May 22, 2018 depends on your tire size really. I ran 18x9.5 et38 with 235/40/18 tires before I lowered my car and i didn't have any rubbing issues This is exactly the set up I am looking to run. 18x9.5 with 235/40/18. Thanks! Link to comment Share on other sites More sharing options...
