boost4life Posted December 28, 2009 Share Posted December 28, 2009 Got a 06 LGT new brake pads 8k ago. The front left is heating up and began to mare / destroy the rotor . it seemed to be sticking as i stopped and i could feel it grabbing , it was also hot to the touch the right side only warm, this was a highway trip..anyone heard of this problem so early ? it has 50k miles..I bleed the brakes also just to see if the problem would go away, no success. Link to comment Share on other sites More sharing options...
SubyShop.com Posted December 28, 2009 Share Posted December 28, 2009 Apply some high temperature grease to the sliders and the "ears" of the brake pads. Make sure there is not a lot of debris that is interfering with the pad movement. If this does not solve the problem, you may need to rebuild the seals on the calipers so that the pistons move freely. -Franz Link to comment Share on other sites More sharing options...
