1astrokeit Posted December 19, 2009 Share Posted December 19, 2009 for those of you that did their clutch install themselves, whether you went with spec or ACT and installed the TSK-3 kit along with it. which method did you use. i know theres a few different ways to do it. im doing my install on jack stands. im also changing to wrx flywheel with ACT clutch and tsk-3 kit. now i want to do the easiest way without droping the whole transmission out, because i know i cant lift it back into place. a guy on here by the name scruit did a nice video of the install and he did the "slide the trans back" method. but my questions is, if i did that method could i install the tsk3 kit with the axles still in trans or would i have to remove them? also if i removed the axles how much more room would i get by removing the axles from the trans? any advice would help me right now. Link to comment Share on other sites More sharing options...
1astrokeit Posted December 19, 2009 Author Share Posted December 19, 2009 no one has any clue? come on i know alot of you guys did it yourself Link to comment Share on other sites More sharing options...
schwinn Posted December 21, 2009 Share Posted December 21, 2009 I did NOT do it myself... after reading the crazy long walkthrough posted by someone else, I realized it was well worth the $525 to have someone else do it... not to mention the time and frustration of running into problems along the way! Do a search for the walkthrough - it's VERY detailed. EDIT: Not to mention there are plenty of threads that describe how they did it anyway... see: http://www.legacygt.com/forums/showthread.php?p=2750836#post2750836 Link to comment Share on other sites More sharing options...
