rymac320 Posted December 18, 2009 Share Posted December 18, 2009 Will 2008 SpecB stock 18's fit on a 2008 GT? I can't seem to find my answer...bolt pattern-wise? If so, has anyone done this - 'upgraded' from the stock 17s on the GT to the stock 18s on the specB? I just love the look of those specB tires. Link to comment Share on other sites More sharing options...
DocHolladay23 Posted December 18, 2009 Share Posted December 18, 2009 sure will [sIGPIC][/sIGPIC] You want stickers? Hit me up here!!! You want a shirt? Hit me up here!!! Link to comment Share on other sites More sharing options...
lucas569 Posted December 18, 2009 Share Posted December 18, 2009 real question is can your GT handle the added power that comes along with any spec b part? CAN IT? dont say you werent warned! Link to comment Share on other sites More sharing options...
kenzo Posted December 18, 2009 Share Posted December 18, 2009 Spec.B wheels are EXTRA circular and add 15hp. Link to comment Share on other sites More sharing options...
rymac320 Posted December 19, 2009 Author Share Posted December 19, 2009 so thats the secret to the specb's tires...theyre circular! Link to comment Share on other sites More sharing options...
mightyS Posted December 24, 2009 Share Posted December 24, 2009 If you want greater acceleration, stay with the 17 inch wheels and get lighter wheels. Plus 17 inch tires are cheaper. Link to comment Share on other sites More sharing options...
Darkness of Death Posted December 24, 2009 Share Posted December 24, 2009 tire size is different Link to comment Share on other sites More sharing options...
ubersoph Posted December 24, 2009 Share Posted December 24, 2009 Aww you're a spoil sport mightyS Link to comment Share on other sites More sharing options...
mightyS Posted December 24, 2009 Share Posted December 24, 2009 ^I know I agree the Spec B wheels look nice. I found from my 1st autocross that lighter wheels make a difference. I didn't feel it until I bought wider and lighter wheels. I switch to the light wheels before a race and back to the stock wheels afterwards (in the winter). It feels like I gain a lot of power just by switching to the lighter wheels. It is amazing what a reduction in rotational mass can make. Link to comment Share on other sites More sharing options...
Darkness of Death Posted December 24, 2009 Share Posted December 24, 2009 lighter wheels are more expensive, aren't they? Link to comment Share on other sites More sharing options...
08LGT80 Posted January 8, 2010 Share Posted January 8, 2010 Spec.B wheels are EXTRA circular and add 15hp. hahahahahaha... and stickers add extra 10hp!! Link to comment Share on other sites More sharing options...
DrCloud Posted January 8, 2010 Share Posted January 8, 2010 The overall diameter of Spec.B tires (at least on my 08) is 1" more than the LGT setup. Because the suspension is different on the two cars, it may be that fitting that extra inch into an LGT wheelwell could be problematic. Has anyone actually done this? (Yes, 18" wheels with the appropriate tires to make the overall diameter unchanged will fit for sure. But will the extra inch of tire?) HPH Link to comment Share on other sites More sharing options...
amp583 Posted January 10, 2010 Share Posted January 10, 2010 bump for added interest Link to comment Share on other sites More sharing options...
jxjjang Posted January 10, 2010 Share Posted January 10, 2010 does that mean that people who did a bilstein HD setup should go for the specB tire size diameter or stay within the stock GT size diameter? Link to comment Share on other sites More sharing options...
jxjjang Posted January 13, 2010 Share Posted January 13, 2010 anyone? Link to comment Share on other sites More sharing options...
wpmarky Posted January 13, 2010 Share Posted January 13, 2010 jxjjang, to answer your question, it doesn't matter what struts you use, The only thing that will make spec.b wheels/tires not fit is if you use rediculously low springs or coilovers. No matter what strut/coilover combo you go with, your speedo will be off because it's callibrated for the stock LGT wheels/tires (225/45/17). For example, when your speedo would normally read 60mph on the stock wheels/tires, it will read 58.5mph with the spec.b wheels/tires (according to that tire calculator). http://www.1010tires.com/tiresizecalculator.asp Link to comment Share on other sites More sharing options...
jxjjang Posted January 14, 2010 Share Posted January 14, 2010 hmm, okay. thanks for clearing that up! Link to comment Share on other sites More sharing options...
peteyjr Posted January 15, 2010 Share Posted January 15, 2010 That tire size calculator is a good tool. I went up in tire size when i changed to Spec B rims (early version) . Running 225/45/18's . No problem rubbing even with lowered suspension. I did have slight rubbing issues when I had swift springs on. I use lighter smaller wheels for Autocross 17's. Spec B rims are not light. Link to comment Share on other sites More sharing options...
jxjjang Posted January 15, 2010 Share Posted January 15, 2010 i was just wondering if the specB tire size will look better on a lowered GT than the GT tire size. i'm lowered on bilsteinsHD's and swifts and i just bought 18x8 wheels.. normally i would've gotten 225/40/18's but i'm thinking about my options here.. Link to comment Share on other sites More sharing options...
peteyjr Posted January 15, 2010 Share Posted January 15, 2010 They will fill the wheel arch more better (double positive) and look mo betta too. On my lowered WRX it looked dorky (oversized) but not on the LGT. Link to comment Share on other sites More sharing options...
jxjjang Posted January 15, 2010 Share Posted January 15, 2010 hmm, these will be the last set of summer wheels/tires i go with, so i want to do it right. on that note, is anyone running 225/40/18 or 235/40/18 or any other specB tire size on a bilsteinHD and swift/pink setup? Link to comment Share on other sites More sharing options...
peteyjr Posted January 15, 2010 Share Posted January 15, 2010 Bilstein will be 1/2 taller from the top hat (compared to stock or Koni's) so you should not have problems with either tire choice . I really only had rubbage when my stock struts wore down after a year and a half on swifts. Link to comment Share on other sites More sharing options...
jxjjang Posted January 15, 2010 Share Posted January 15, 2010 well i used 225/40's last summer, and i had a good amount of clearance. i was just wondering whats the largest tire i could use safely haha. some people say that they rub on 235/40's... Link to comment Share on other sites More sharing options...
