maddoc Posted December 14, 2009 Share Posted December 14, 2009 Last night I installed a Perrin TBE (Catted DP, Mid, and y-pipes, stock cans). I loaded up the COBB Stg 2 93 octane OTS map on my AP and headed out. I found that as I started getting into the higher RPMs I would get a buck or shudder from the car. I immediately let off the gas. The problem is exactly the same as my old RS w/ an STi swap... am I overboosting? I plan to ditch the AP v2 and move to an open source tune hopefully within a week or 2, but in the meantime, will I be ok? Link to comment Share on other sites More sharing options...
NSFW Posted December 14, 2009 Share Posted December 14, 2009 If you hit the boost limit, you'll get fuel cut (very abrupt power loss, almost feels like hitting the brakes) and you'll get a check-engine light. Since you didn't mention a CEL, or the flashing cruise-control light that comes with it, I'm guessing that's not what happened. Before my turbo upgrade I ran for quite a while with an Invidia catted DP, Perrin's mid/Y, and stock cans. What you describe never happened to me. If you can data-log with the AP, that might help troubleshoot the problem. Link to comment Share on other sites More sharing options...
maddoc Posted December 14, 2009 Author Share Posted December 14, 2009 No CEL, but very abrupt bucking of the car, more when the car is 75% to WOT. Another thing I noticed is I'm hearing a backfire (detonation? pop-pop) that I can hear out the exhaust if I rev it. I have an older tactrix cable, but I'm not sure it will work on a DBW car (I picked it up in '06 or '07) Link to comment Share on other sites More sharing options...
proflatlander15 Posted December 18, 2009 Share Posted December 18, 2009 Ever since I added a UP and DP to my car, the check engine light and flashing cruise light has come on. The code is for a front O2 sensor and lean condition. Could this be due to boost creep? I seem to lose power (or boost) over 3500rpm. Link to comment Share on other sites More sharing options...
TravisCOBB Posted December 22, 2009 Share Posted December 22, 2009 No CEL, but very abrupt bucking of the car, more when the car is 75% to WOT. Another thing I noticed is I'm hearing a backfire (detonation? pop-pop) that I can hear out the exhaust if I rev it. I have an older tactrix cable, but I'm not sure it will work on a DBW car (I picked it up in '06 or '07) Backfire is not detonation, what you are experiencing could be a misfire, which is different. Have you changed your spark plugs to a one step colder plug with a tighter gap? Do you have any intake leaks? I would start looking for vacuum intake leaks as it looks like you are going way rich, not lean which is where detonation would start occuring. Ever since I added a UP and DP to my car, the check engine light and flashing cruise light has come on. The code is for a front O2 sensor and lean condition. Could this be due to boost creep? I seem to lose power (or boost) over 3500rpm. If you have a front 02 sensor code, that means the front 02 sensor is going bad, this is not boost creep. Replace the sensor and your car will run perfectly again. Travis COBB Tuning Link to comment Share on other sites More sharing options...
CapnJack Posted December 23, 2009 Share Posted December 23, 2009 When I went stage 2 on my LGT, I had the same problem you are having. It would overboost like crazy every time I put my foot in it. FYI, I was running a Cobb catted DP, stock exhaust, and AVO TMIC. I researched the hell out of it and the ultimate solution was to get it pro-tuned. Some had mentioned changing pills, others that I should run an EWG. I ran the car for about 3 months, but just learned to keep my foot out of it as it would overboost every time. Before I got pro-tuned, I added an SPT catback and an AVO panel filter. Ever since then, the car backfires after high RPM shifting. I've heard its pretty common running a more open exhaust such as I am doing. I then had it pro-tuned by arguably one of the best Subaru tuners in the nation and have not had an overboost problem. My boost targets are spot on now. I still have the popping after high rev shifting, but have learned to deal with it and it gives the car character. Link to comment Share on other sites More sharing options...
captainhook Posted December 23, 2009 Share Posted December 23, 2009 /\ I had the same experience as you (Cobb intake, cobb catted DP, SPT CBE), after a month I was fed up with the constant overboosting and got it pro-tuned by Precision Tuning in NJ. Surprise surprise, boost targets were spot on and it ran much smoother afterwards. Link to comment Share on other sites More sharing options...
Long Island Legacy Posted December 24, 2009 Share Posted December 24, 2009 What is happening is your getting very brief boost spikes, On my car I've seen them as high as 22psi, I also had a catless DP, but the OTS map is terrible, I don't think anyone should use it unless it temporary. It will destroy your engine over time. The buck is your car over boosting and the engine trying to compensate. Link to comment Share on other sites More sharing options...
subawang Posted December 24, 2009 Share Posted December 24, 2009 Travis/Cobb, Can you comment on the above posts whereby a catted DP was used but still they experienced over-boost? I've been following closely, and Cobb continues to deny any over-boosting when a catted DP is used. Link to comment Share on other sites More sharing options...
Long Island Legacy Posted December 24, 2009 Share Posted December 24, 2009 Travis/Cobb, Can you comment on the above posts whereby a catted DP was used but still they experienced over-boost? I've been following closely, and Cobb continues to deny any over-boosting when a catted DP is used. they will deny it somewhat, I've talked to christian over at COBB and he said it was a catless prob. Bottom line is, dont run the OTS maps at all, they will ruin your car. Trust me, I can prove it to you. Link to comment Share on other sites More sharing options...
Boostin1657615274 Posted December 27, 2009 Share Posted December 27, 2009 Post some data logs. How else would anyone be able to help you? On the search for a new DD... Link to comment Share on other sites More sharing options...
NSFW Posted December 27, 2009 Share Posted December 27, 2009 Post some data logs. How else would anyone be able to help you? +1 And be ready to tweak some numbers in your tune. (If you are not willing to do both, then just pay a tuner to do it for you.) Link to comment Share on other sites More sharing options...
