slimjoe Posted December 11, 2009 Share Posted December 11, 2009 I had a thought, it doesn't happen very often but here goes. From what I remember, when I had my car last aligned, the caster between the front right and left was about 0.5* off from each other (I'm thinking ~6* and ~5.5*).Currently, my LCA bushings are torn and I need to have them replaced. So here's the thing, would it be unheard of or even unsafe to replace the bushings with a mixed set? What I mean is, AVO produces both standard and 0.5* offset LCA bushing. Could I use the standard bushing on one side, keeping it at ~6* and then the offset bushing on the other to raise it to ~6*? Would there be any noticable advantage to this as opposed to just using +0.5* (or even +0.0*) bushings on both sides? Link to comment Share on other sites More sharing options...
N.sane Posted December 12, 2009 Share Posted December 12, 2009 I had my alignment done recently and my caster were a little off between left and right too. Apparently it's normal, the shop is very reputable in my local Subaru community. I was surprised I was able to achieve around 6.5 caster with the stock bushings, I'll double check the alignment spec sheet when I get home... Link to comment Share on other sites More sharing options...
slimjoe Posted December 12, 2009 Author Share Posted December 12, 2009 Not that it really matters but I found the alignment summary sheet from the last time. Initial Caster L/R: 6.57/6.03 Final Caster L/R: 6.68/6.20 Prior to that, it looks like I was at 5.7/5.14. So yeah, there's about a 0.5* difference in caster in my car. Link to comment Share on other sites More sharing options...
N.sane Posted December 12, 2009 Share Posted December 12, 2009 Ok, mine's 6.71* left and 6.25* right. So I've got about a 0.5* difference too. I guess it's safe to say it's "normal" Link to comment Share on other sites More sharing options...
slimjoe Posted December 12, 2009 Author Share Posted December 12, 2009 Well, the question isn't if the difference in caster is normal but if would be advantageous, or safe, to match a standard bushing with an offset bushing on the front LCAs to bring the caster on both sides to the same angle. Link to comment Share on other sites More sharing options...
OhBe1 Posted December 13, 2009 Share Posted December 13, 2009 IIRC, Rallitek sells the AVO bushings as mix and match specifically for this reason. 06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest. Link to comment Share on other sites More sharing options...
