After snow fall car is acticng funny
We got about 8 inches and my car was caked with snow. I went and got the car washed and got most of the snow out of the wheel wells. I noticed tonight, when I turn the car, that I hear a crunchy noise (like anti-lock brakes), but it happens when I am moving and not applying the brakes. Then when I got on the highway tonight the car had a horrible shudder that worsened with speed. At 70 the car shakes like a detoxing junky. I pulled over and all tires look good. :confused:
Any one got a hypothesis?
any snow caked inside the wheels? ice in there will definitely affect the wheel balance.
The amount of snow left in the wheels is minimal. What's weird is that the car didn't have any shudder today when it was covered like a snow sculpture. I'll go out with a broom handle and try to knock the dang snow out of the rims. Now I wish I had the stockers instead of the intricate 10 spokes. I hope it's snow.
Upon closer inspection there was a ton of ice inside the wheels. When I went through the car wash (twice) the hot water and the snow coagulated into heavy heavy ice. There had to be a few pounds worth in each wheel. Half of the mystery is solved. Still trying to figure out the crunchy noise...
inside the wheel well, the area surrounding the tire. if there's snow/ice in there, when you turn the front wheels will rub against it. if there's enough, the wheels will rub against it when you're driving and can cause some vibration on the highway.
The LGT wheels hold an amazing amount of snow.
the noise could also be the ice. Park it somewhere warm and don't worry about it unless it is there after a thaw.
This would happen with my old car all the time I had some thin 5 spokes on, spraying it was the only way I could really get it back to normal . And yeah I was really suprised to see how much snow these LGT rims can hold, the other day I came out of work and it looked like my car had a white lip behind the wheel actually kinda looked cool.
another option is to get wheels that just barely fit over the brakes, then the caliper will knock most of the ice off when you start to drive. Worked in my STi with the stock wheels! :lol:
Lol. Or my some chance, it'll knock the caliper off and royally pwn you.
You just need to drive faster to get rid of the ice stuck inside the wheel.
...I went and got the car washed and got most of the snow out of the wheel wells. ... Then when I got on the highway tonight the car had a horrible shudder that worsened with speed. At 70 the car shakes like a detoxing junky. I pulled over and all tires look good. :confused:
the wet snow turned to ice and unbalanced your wheels. Happens a lot.
